sandy1010
- Nov 17, 2014
We have fully tested the 400GB cards with all of our players, including the AK380 and have found no issues. We recommend formatting the cards as FAT32 for best results.
Most likely the issue is a corrupt tag or file. You mentioned there is no issue with the files on the internal memory, but only ones on the card. Do you have the same files in both internal memory and the card to rule out a corrupt file causing the issue?
My suggestion would be to copy files to the card in batches and test. If you run into a problem with one set, most likely it is a file in that set causing the issue. I know this is not a simple solution and takes time. Most cases we have found it was a file that didn't copy correctly when loaded on the card or player or it was corrupt to begin with.
Thanks.
It must’ve been a corrupted lyric tag then. I cleared all the lyric tags and ran a repair on the SD card, it now works fine.
Different files on the internal memory but all the lyric tags were done in the same manner.
