Nah......AK380 ---> OTG Micro USB Cable ---> Mojo (or m9XX) ---> HD800S
The USB audio will not work if connecting via the AK380 amp.
on the street tried to go with this bundle?
[COLOR=111111]on the street tried to go with this bundle?[/COLOR]
Apologies....I don't understand your question.
[COLOR=111111]I still learn English dude, I asked you are using this player with amplifier on the street or only at home?[/COLOR]
Why on earth would you do that even?
I wasn't intending for AK380 + Amp -> Hugo.
I was thinking more along the lines of AK380 (whilst connected to the Amp) + Hugo.
Because if I were to use the Amp when I'm on the go, it would be troublesome to keep removing the amp to connect to the Hugo everyday. It would probably loosen the leather casing also !
Just a quick idea, what about connecting to the Hugo via the Optical Link ? Is it possible to connect to the Hugo with the Amp attached to it if I'm using the Optical Link ?
You do not need to remove the amp when connect through optical. Optical output goes from the 3.5mm single ended port from player which is at the top.
hi guys,
i've never seen them both in person, but which case quality is actually a better made, Aesopica or Dignis (for ak380+amp), pls help me to decide.
Thanks.
In case anyone is interested I posted an overview - sort of review of the RWAK380 with the Empire Ears Zeus R
http://www.head-fi.org/t/786335/empire-ears-discussion-impressions-formerly-earwerkz/2250#post_12765639
If you are able to comment on the RW mod on the 380 I would be very interested. Do you notice any changes? If so what are the changes? I also have the therium and liked it a lot. Thanks for the review.
@Apina, thanks for the feedback. I recently did the RW mod for my AK240ss and did not like the new sq. I thought the sq became warmer after the mod and I felt I lost the cleaner feel of the 240ss. I was going to mod my 380cu after my 240ss but became hesitated because of the change with my 240ss mod. I really liked the openness and airy feeling of my 380cu now and worry the the mod will change that. I agree the 380 alone is sufficient for most iems.
I was going to sell both the RWAK380 and RWAKAMP and get the copper version of the AK380, after talking to Vinnie he said it's not worth the extra money. He has modded both units and said inside they are identical in every way. With the same SW he mentioned in a blind test you would hear no difference.
