ste787
- Apr 6, 2014
I'd say just get a reasonable dac/amp to pair it with your smartphone. Absolute Sound said the headphone out is a little weak. What is your experience driving your HD800 with it? Sounds like it's an excellent DAC/preamp though!
Anyway the lower end AK's like AK100ii or AK120ii might do you well. Or even the Jr. Are the portable headphone/IEM you are using hard to drive?
Exogal headphone out is useless for HD800, therefore i use RCA to 3.5mm to connect to my HD800. It works well in that case.
I tested all the DAP from AK100 , to Jr, cowon P1,P M, all sound rubbish to me. No, all my portable headphone and IEM not hard to drive, ultrasone edition 8 and shure SE846.
Only AK240 and AK380 sound remotely decent to me.
Exogal with HD800 sound different from AK380 and Layla. With AK380 and Layla, the music gone softer and voice gone louder. It is like comparing KRELL with AUDIO RESEARCH.
Exogal sound like krell. The later sound like ARC.
I need both. Switch around depend on the songs.
If i would use AK380 to connect to EXOGAL, i think it will be fantastic.
