Astell&Kern A&ultima SP3000
Oct 3, 2024 at 8:18 AM Post #4,666 of 5,513
M means small?
This sounds like the same deal with the SP1000 and SP1000M, I've owned both of them at different points of time.
Interesting, so there will be a smaller and cheaper SP3000 coming out soon.....
Oct 3, 2024 at 8:20 AM Post #4,667 of 5,513
For those of you that have owned the SP3000 for several month to a over a year, have you ever been disappointed with the battery life in the SP3000?
Is the battery life worse than the SP2000? Battery life was a common complaint of the SP3000 in many video reviews I have watched.
What IEM pairings would you recommend with the SP3000?
Annihilator 2023? U12T?
Oct 3, 2024 at 8:41 AM Post #4,668 of 5,513
EE Odin with a touch of EQ
Oct 3, 2024 at 9:38 AM Post #4,669 of 5,513
I have no complain with the battery and using annihilator 2023
Oct 3, 2024 at 9:52 AM Post #4,670 of 5,513
Anyone have any guess when the SP3000M will release?
Does anyone have data on when iRiver had the FFC ID Patent for the SP1000M, like when it was submitted? We can then take into account when the SP1000M actually released, this might give us an idea on when the SP3000M might release 😊
The submit date for the SP3000M FFC ID is
08/29/2024
Oct 3, 2024 at 10:09 AM Post #4,671 of 5,513
Tidal HiRez LED indicator report.... I was using AK Connect and the JPlay for IOS app in Tidal mode. I searched a HiRez track (48khz 24b) and with playback the LED illuminated green. I then turned off AK Connect and used the side loaded Tidal app (2.122.0) and brought up the same track. Tidal showed it as Max (48lhz 24b) but the LED now illuminated red. In built Tidal app showed HiFi and indicated red. It would appear AK needs to pursue this as Jplay and roon seems to have the correct API interfacing.
Oct 4, 2024 at 10:16 AM Post #4,672 of 5,513
Would you guys say that the SP3000 is also suitable for electronic music? Or does it have slightly slower transients that benefit acoustic type music more?
Oct 4, 2024 at 4:44 PM Post #4,675 of 5,513
He maybe\probably intends uncompressed and very transparent transients .. Which makes it easier or easy to 'look' or appreciate 'minutes' or micros of parts with sp3000..
Just a guess
My answer would be yes.. but fast electronic will sound fast..
Oct 4, 2024 at 4:55 PM Post #4,676 of 5,513
Just a guess
Yes I mean Macro/Micro, sorry for the confusion.
Good to hear that EDM and other forms of electronic won't sound "too slow" with the SP3000. Most IEMs don't have that problem it seems only the DAP source does. I was worried that the SP3000 might have too much decay that would throw off the transient speed needed for electronic music.
Oct 4, 2024 at 5:29 PM Post #4,677 of 5,513
Anybody else having a problem with the SP3000's DAR light showing the wrong color? @Jason After downloading the newest firmware the DAR light sometimes shows pink when it should be blue.. If you turn DAR off then on again it goes back to continuous blue like it should be. By the next song it sometimes turns back to pink again This is happening while playing my Qobuz favorites list. Haven't tried anything else yet.
Oct 4, 2024 at 7:30 PM Post #4,679 of 5,513
Anybody else having a problem with theSP3000's DAR light showing the wrong color? @Jason After downloading the newest firmware the DAR light sometimes shows pink when it should be blue.. If you turn DAR off then on again it goes back to blue like it should be when it's been turned on But by the next song it turns back to pink again
I’ve noticed the purple light on at incorrect times since the update.
Oct 5, 2024 at 12:38 AM Post #4,680 of 5,513
Rarely post in this forum, but a keen user of the AKSP3K. I have been countless rabbit holes, Mojo2, Dave with power upgrade etc… just wanted to share the two amazing life-changing tweaks I encountered with the AK : 1) PGGB remastero and upsampling offline to DSD512, to exploit the direct DSD pipeline of the AK, absolutely transcendent experience, you can try a free license to experiment (I dare say way beyond Chord Dave in PCM mode, arguably you could use the Dave in DSD+ mode, never tried), 2) use an external amp, even for iem, it reduces largely the onboard RF and noise, and filter the RCA output with the Audiowise SE RF-stop, it uses well tested skin effects to damp RF propagation back to the DAC. The effect is akin to diving back into the music and that mostly so far you’d just have been doing guess work as to the spatial cues. Both may be expensive (in the 1k territory), but the kind of addition that you’ll never regret and got me excited enough to share here. No affiliation of vested interest, just a happy camper with the AK for a minimal system that can really compete with anything out there, desktop rigs included.
As a headphone amp I use the Enleum 23RM, so you can play fully off main powers, that helps with signal integrity. Hope that may help!
  • Back
