maceto
- Jul 4, 2009
In terms of options/value the N8ii is the better value, but do you tinker with it all the time or have you landed on one sound? And what sound is that? Similar to AK or something very colored in comparison? From a features perspective you get a lot more in the N8ii - a lot more. It’s almost like comparing a Nissan Skyline GTR with Lamborghini.Well I have both of them now.
If we talk about portability SP3000 is a bit more compact and not so bulky with a bigger screen, but N8ii battery last much longer.
It also looks much more luxurious while Cayin has those techno-geek vibe.
In terms of sound quality the biggest differences to me are the following:
1. SP3K has literally zero hiss and the best control over all frequencies - very clear, crisp and not diffused if track doesn’t call for it, but it’s not a dealbreaker for me. Like when I listen to N8ii I don’t have a feeling that I’m missing something.
2. N8ii provide a better sense of scene depth and layering as SP3K has more elevation in sub bass and highs which makes it more forward overall.
That is also a reason why N8ii has a better defined bass line for example.
3. N8ii not only have tubes but a switch for class A or class AB amplification. Using those options you can change sound signature significantly.
4. SP3K has a system wide upsampling option (for everything except MQA). While you can install say Neutron player app for the same purpose it won’t work for streaming.
Regarding your question on desktop DAC - I’ve sold them all and just enjoy using DAPs as a source to my amp
It’s also convenient as they are battery powered so you don’t have to deal with line power purification.
Only DAC I still want to buy is something like HOLO Audio May KTE as I don’t think that you can build an R2R DAP of comparable quality (due to physical dimension of components needed).
If you know your cars…
