Just installed apple music 3.6.0 beta and it's running perfectly On my SE200. Best device for apple music.The latest firmware update, v1.22 fixes the issue with Apple Music 3.5.0 running on the SE200. There should also be no issues with Apple Music 3.6.0, which supports lossless when it is eventually released.
Astell&Kern A&futura SE200: First DAP With Multiple DACs - Head-Fi TV
- Thread starter jude
On my Hiby R8 I can see that Apple Music sample rate switches, as the rate shown on the taskbar matches the rate on the "taskbar" matches the rate on the song.
Do you know if the sample rate switching is working on the SE200? I can see the led turning blue for highres songs, so at least I know it's playing at 32 bit, while for lossless only is stays red. Is there a way to know the sample rate on the DAC?
Luis Mad
Please tell, which version of beta did you install? Which source?Just installed apple music 3.6.0 beta and it's running perfectly On my SE200. Best device for apple music.
It was a pain. I got it from apkmirror and than I had to unzip, shuffle files around and rezip to make into an apkpure to install. Which ofcourse I didn't document. version is 1111 I believe.Please tell, which version of beta did you install? Which source?
Luis Mad
Thanks, I got to the first part: apkmirror, unzip,It was a pain. I got it from apkmirror and than I had to unzip, shuffle files around and rezip to make into an apkpure to install. Which ofcourse I didn't document. version is 1111 I believe.
but how do you shuffle the the files and rezip to make into an apkpure? any help would be greatly appreciated!
It has been discussed in numerous posts in this thread, but the LED does not display the bit rate color for any music played via apps sideloaded. The LED color will only display the correct colors for bit-rate when playing tracks using the default music player and embedded Tidal app as those are hard coded into the firmware. All apps installed via OpenAPP do bypass the Android limitations and play at bit-perfect playback of the original file rate.On my Hiby R8 I can see that Apple Music sample rate switches, as the rate shown on the taskbar matches the rate on the "taskbar" matches the rate on the song.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
If I remember well steps were:
1) download apple music 3.5 from apk pure
2) download apple music 3.6 from apkmirror
3) I extracted them and compared the folders
4) I replaced the files in the apkpure by the respective files in apkmirro, keeping the directory structure
5) I remember editing the apkpure manifest file, probably a json, with the details from a similar file in the apkmirror
6) Rezip
7) Pray
8) transfer to se200
Enjoy!
6) Rezip
7) Pray
Enjoy!
I canl try to rescue the file with android file transfer and post a link her if you want?Thanks, I got to the first part: apkmirror, unzip,
Found it! here is a link Apkpure icloud link
Luis Mad
That would be great! I am trying to install in SR25 which I guess is the same operating system as SR25, I tried without the last steps and could install but not make it workI canl try to rescue the file with android file transfer and post a link her if you want?
It only worked for me (today actually ) after I installed the version 1.22 of the OS. Before no luck.guess is the same operating system as SR25
I mean the same file crashed on startup with os version 1.21
When did u get the last update to the SR25? My update showed up only todayI guess is the same operating system as SR25
Luis Mad
Many thanks! It works! Streaming hires on my Sr25 with Apple Music!When did u get the last update to the SR25? My update showed up only today
De Nada!Many thanks
