What about non working EQ?
Hello,
What do you mean about the non working EQ ??
Hello,
The EQ does have a use case for me - to further cut down volume on top of volume 1. I turn it on for my sp1000m with Solaris before sleep. I'd say AK's EQ does deliver something to me.Have you had any of latest AK devices yet? It's well known that the built-in EQ has almost no effect.
It's more of an eye-candy EQ which looks good but doesn't deliver anything.
I guess AK doesn't want you to fiddle around with the tuning that they did a lot of research and concept for.
Ok i know what you mean... Well, i agree with you in the fact that their EQ is very shy , yes...Have you had any of latest AK devices yet? It's well known that the built-in EQ has almost no effect.
The LED light will glow red for playback of any track, regardless of bit-rate for all apps installed via OpenApp. The LED will only display bit-rate color for tracks played back through the main player app (tracks stored in internal memory or microSD card) and the embedded Tidal app since the embedded Tidal app it is hard-coded in the firmware.Hi everyone,
I’m new here, been lurking for a little while.
I finally got the SE200 today, I updated to the latest firmware 1.10 and I installed the Tidal app through Open APP services, however I noticed that when playing 24-bit MQA tracks through the Tidal app I just installed, the light on the volume wheel remained red (meaning the device thinks it’s playing a 16-bit track). When I played the same MQA track using the built-in Tidal app that comes with the device, the light on the volume wheel would display the correct colour to show it was playing a 24-bit track. This happens regardless of whether I’m using the AKM DAC or the ESS DAC.
Has anyone else experienced this issue? Is it just a software bug?
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
Correct. If you select a 24-bit track, it is playing back in 24-bit.Hi Jason,
Thanks for the quick response. I take it the bit-rate of the track being played via an app installed via OpenApp is not affected in this case?
So for example if I’m playing a 24-bit MQA track via the Tidal app I installed, and the volume LED is glowing red, the track will still be playing in it’s original 24-bit as far as playback is concerned?
