Asking G: Microphone techniques in recording
Mar 2, 2023 at 1:10 PM Post #31 of 54
G, have you ever recorded a harpsichord? I'm guessing that is difficult. It doesn't produce a lot of sound, there are almost no dynamics, and it's easy for the sound of the mechanics to thump thump thump under the music. I have some recordings that sound nice, and others that sound like "two skeletons making love in a closet" as Sir Thomas Beecham described the sound of the instrument.
Mar 2, 2023 at 5:23 PM Post #32 of 54
Yes but only once, for a couple of days and it was many years ago.
It’s not too bad, there are certainly some quieter ones. The difficulty comes when trying to get a balance with modern instruments. Modern string, woodwind and brass instruments are significantly louder than period instruments.
It has no dynamics at all. The only way of getting something louder is by doubling the notes/putting more notes in the chords. This is a good thing from a recording perspective though, instruments with a wide dynamic range are more difficult to record. Incidentally, there were some harpsichords made with a second keyboard and a second set of strings, using an extra string per note. This keyboard therefore produced a bit more volume than the other, so there was a bit of dynamic range available.
Depending on the different constructions it can be a problem. Generally we mic a harpsichord pretty much the same as a piano. However, in an ensemble recording it’s more likely we’ll have the lid lower or as close to closed as possible, to provide some isolation. We can get the thump problem with a piano as well, although usually it’s the pedals that can be the problem. It’s definitely worth making sure the felts and leathers are relatively new when recording a harpsichord. Older leather can harden and between that and worn felts, you’ll have a problem. We would probably rely a bit more on mics slightly in front of the harpsichord in the case of a solo/unaccompanied instrument, to get a bit further away from the plucking mechanism but in an ensemble we’d probably be restricted to mics inside the instrument. In this case we’d probably have the mics somewhat further away from the mechanism than we would with piano hammers.
Harpsichords produce a lot of HF from the plucking action, so dynamic mics would theoretically be a good choice but the relatively poor sensitivity of dynamics probably rule them out. You’ll need a good compressor and probably some HF reduction.
G
Mar 2, 2023 at 5:50 PM Post #33 of 54
G
Do you know if Academy of Ancient Music records in studio? Wonder if it's ever preferable to have period instruments in another venue (or not if your placement of microphone is closer)? When you're mixing for period instruments, do you try to add in reverb/delay to give a sense of acoustics?
I was fortunate to see them once at the Savannah Music Festival. We were waiting to get in the venue, which was an old church that was all masonry. We were also fortunate that we were standing next to the musicians for a short time. They were really excited about performing in this particular church due to its layout/size/stone masonry. And the program was Bach's Brandenburg concertos (the acoustics were really great for me to hear all the instruments in a balcony).
Mar 3, 2023 at 3:05 AM Post #34 of 54
No, I don’t know. As they are based at Cambridge University, I would think they often record there because there are potentially numerous rooms appropriate for recording.
Wonder if it's ever preferable to have period instruments in another venue (or if not if your placement of microphone is closer)?
Preferable to whom? For the recording engineers, probably not but for the ensemble it’s probably preferable to use a room of the period or earlier. Period instruments were designed for relatively small rooms or churches. Orchestras were really just medium or large ensembles at that time, typically only a dozen or so musicians in the early baroque period but up to as much as 40 by the end of the classical period.
Again, I don’t have much experience with period instrument recordings but I would guess mic usage is broadly similar to modern orchestra recording, although the old questions of “what do we want to and up with and how do we want to get there?” is very relevant. So, we could use either a very well placed array over the orch plus some room mics or the same thing but with additional spot mic’ing, although the former would likely be preferable in many cases.
There was quite a vociferous argument raging when I was a music student (and later) between those who were fairly hardline/fanatical about period instruments and those who argued that not enough was known about performance styles and other factors (such as tunings for instance) of the period to justify strict adherence to period instruments/practices. The Academy of Ancient Music was at the forefront of that argument (on the hardline side) and assuming that’s still the case, I would guess they’re philosophically opposed to the idea of studio recordings with artificial reverb, etc. Although, Air Lyndhurst is one of the top two or three studios in the UK and is a converted church so probably would be acceptable.
Modern convolution reverbs would be a potential option along with more emphasis towards spot mics, especially with a custom recorded impulse response but might again be a step too far for some. Again though, I have little experience working with period musicians and what I do have was many years ago, before the existence of modern convolution verbs, so I don’t know the current attitude towards this type of production.
Incidentally, we wouldn’t use delay in orchestral/classical music recording to “give a sense of acoustics”, although we might delay certain mics due to timing differences or to give a sense of a larger acoustic space when applied to some of the room/ambience mics.
G
Mar 3, 2023 at 3:19 AM Post #35 of 54
I have some multichannel orchestral recordings that were miked with dozens and dozens of mics and the soundstage and hall ambience were created entirely in the mix. They actually aren't too bad. You lose the particular character of the venue, but the sound object placement and detail of the recording are excellent.
Mar 3, 2023 at 4:04 AM Post #36 of 54
I am amazed by the number of albums they have out, and considering the different sizes of ensembles/small symphony, was thinking out loud about if there's instances for open spaces. We had a short exchange about SACD: actually bought their Brandenburg concertos disc after the performance, which is hybrid SACD.
I was going for opinion of audio engineer. It seems it's preferable that the microphone placement is where you get the most direct recording of the instrument (IE no reflections that's not primary to the intonation of the instrument)?
G
Ah, interesting to see how Academy of Ancient Music have always been hard liner purists including possibly recording/mixing. Well at least with their performances, their adherence to period instruments can be a treat. We previously brought up about how when you're in an auditorium, there's hidden mics and speakers so there's not a pure acoustic performance. Well maybe also that I have a big background in photography (forgive me), a "natural" photograph can be heavily edited. Most folks know about Ansel Adams...most his time was spent in the dark room. He knew what camera setting he needed to expose, and then it was hours to "tonemap" that well exposed 14 stop film negative to 8 stop paper print. I'm one of those that know what optimal exposure I should have and also intend what I need for editing
I think Ansel would have been really excited about how much more tools there are with digital. Interesting that given how the most current digital workflows are pretty unlimited for things, you're indicating that there's still no need to add delay to many tracks with orchestra music, except maybe a few mics with adjusting timing.
Mar 3, 2023 at 4:11 AM Post #37 of 54
The best SACD I have for multichannel is actually originally a quadrophonic album from the 70s (Bach toccatas from 4 organ cathedral). It's amazing to me how much it gets expensive after so many years out of print
https://www.amazon.com/Bach-Four-Great-Toccatas-Fugues/dp/B00008PX99
Mar 3, 2023 at 9:33 AM Post #38 of 54
What’s preferable is what you want to end up with and how you want to get there. So it’s preferable in some situations to have close mics to capture the most direct sound but not in others. In most acoustic classical music, spot/close mics are used to reinforce the main array, (of certain instruments/instrument sections at certain times). In this case, the use of spot mics is to gain some degree of isolation/separation and capturing more direct sound/fewer reflections is actually an unavoidable disadvantage. This explains the slight nomenclature difference between “spot mics” and “close mics” even though physically they can be the same thing.
TBH, I have no idea if they are as hardline with record/mixing. It’s a fair assumption based on how hardline they can be about the instruments but it’s nothing more than an assumption.
That’s typically only in the larger concert halls and is only sometimes the case.
Well maybe also that I have a big background in photography …
Not sure a photography analogy is appropriate. In music, while the manufacture of instruments obviously has quite an impact on the sound, how you play those instruments (performance styles/conventions) also has a large impact and the problem is that scores particularly from the C17th but even the C18th provide very few clues. They usually don’t even contain all the notes in the piece let alone any stylistic directions and we do know that at least somethings must have been significantly different, though not how. For example, certain things (most commonly found in brass parts) are not possible with the instruments of the period, unless they performed them in a way that is now lost or unless sensibilities at the time were so vastly different to even the C19th musicians/audiences that it is now impossible to imagine (EG. It would just sound like a horrible mistake, like a modern “beginner”).
G
Mar 5, 2023 at 6:29 PM Post #39 of 54
Since we were on the subject of recording and acoustics of an area, New York Times just posted an interesting interactive article about how they're using computer simulations to figure how sound (and music) would sound in different areas of Notre Dame. Don't know if in the end it needs to be 100% reconstruction if that's beyond a practical threshold. Saw a documentary about other aspects of the restoration. They had to do a lot of investigation about the stain glass: it changed quite a bit with structural improvements during 19th century.
If you're not a subscriber, you should still have access if you haven't visited the site previously this month (they recommend listening through headphones):
A Cathedral of Sound
Mar 5, 2023 at 8:02 PM Post #40 of 54
Yamaha did that with the DSPs they use in their AVRs. They're all based on venues, from The Bottom Line to the Musikverein.
Mar 5, 2023 at 8:08 PM Post #41 of 54
Yamaha reconstructed Notre Dame with their DSPs? There was several specific Notre Dame positions pre fire? Simulating different acoustic environments to an extent: many audio brands have. I was a Harman Kardon fan until they were bought out and left the speaker amp scene. Many people liked their Logic 7 matrix surround over Dolby's or DTS: my receivers would also have some venue DSPs.
Mar 5, 2023 at 10:11 PM Post #42 of 54
I don't know if they did that one. But they did over a dozen different acoustics all over the world.
Mar 5, 2023 at 10:25 PM Post #43 of 54
A dozen different general acoustics, sure. But the NYT article is going over more advanced modeling of one location: full reconstruction of each area in the cathedral based on materials and and dimensions. I just find it amazing that they also have an acoustics team that can help dictate how the reconstruction should go. They've been having to do quite a workflow in cleaning all the masonry, as it's caked with centuries of dust containing lead. I would think lack of that dust on stone surfaces could effect sound reflections (in the scheme of things, maybe not significant). Also would be hard to be a "purist" if there were structural changes outside/upper portions during 19th century.
Mar 5, 2023 at 10:34 PM Post #44 of 54
No, specific acoustics. The Berlin Philharmonic hall, the Vienna Musikverein, The Bottom Line, The Roxy, specific venues. They went in and measured the acoustics all over the house and built a DSP based on that.
Mar 5, 2023 at 10:47 PM Post #45 of 54
I'm still skeptical that they would be able to model those venues at the same level as what's being done with Notre Dame now: especially if your DSP won't let you set specific areas at The Berlin Philharmonic hall.
