EnOYiN
- Jan 13, 2007
I think it does.
The easiest way to check this is to install the ASIO plug-in in Foobar or whatever you are using and see if your soundcard produces any sound. If it does then it supports ASIO.
Originally Posted by Suzuka /img/forum/go_quote.gif How do I know if I already have Asio or not? I have X-fi card xtremegamer by creative. |
Technical Specifications 24-bit Analog-to-Digital conversion of analog inputs at 96kHz sample rate 24-bit Digital-to-Analog conversion of digital sources at 96kHz to analog 7.1 speaker output 24-bit Digital-to-Analog conversion of stereo digital sources at 192kHz to stereo output 16-bit to 24-bit recording sampling rates: 8, 11.025, 16, 22.05, 24, 32, 44.1, 48 and 96kHz ASIO 2.0 support at 16-bit/44.1kHz, 16-bit/48kHz, 24-bit/44.1kHz 24-bit/48kHz and 24-bit/96kHz with direct monitoring Enhanced SoundFont support at up to 24-bit resolution |
I think it does.
