gregorio
- Feb 14, 2008
You could have saved yourself all that typing & just given us the soundbite version "bits are bits" but you would still be wrong - in mixed signal systems, the incoming noise can have an effect on the analogue part of a digital to ANALOGUE converter.
What is it about this that you don't understand?
The irrational reasoning part, IE. All of it!
If the incoming noise on the digital signal has an effect on the output of a DAC, then either the noise is so extreme as to almost obliterate the square wave or the DAC is not performing the fundamental purpose of why digital audio was invented in the first place!
What is it about this that YOU don't understand, it's simplified enough for a 10 year old to understand? No need to answer this question, we all already know what it is, as detailed in my last post!
G
