First Times is already excellent, even no shielding .Thanks. Shielding or non-shielding in my setup (DX320 LO)? Difference is about 30%, but would the Orpheus be that much different?
Orpheus is the best, but has a higher cost.
Newbie question again: does shielding produce a darker background, or darker tone, or none of the above outside of preventing interference (if any)? Thanks.First Times is already excellent, even no shielding .
shielding gives you incredible black background, sharp transients, notes coming at you from completely empty space .Newbie question again: does shielding produce a darker background, or darker tone, or none of the above outside of preventing interference (if any)? Thanks.
I'll bite the bullet and get the Orpheus with shielding. More than cost of the amp itself, but prob worthwhile. Thanks again.shielding gives you incredible black background, sharp transients, notes coming at you from completely empty space .
and yet there's always 1 more question : If used in battery mode (standalone, no charging wire), does adding the PS100 make a difference, or just getting more battery power?I'll bite the bullet and get the Orpheus with shielding. More than cost of the amp itself, but prob worthwhile. Thanks again.
I advise you to add the power supply, because the sound performance of the A100TB gets a further improvement, as well as getting a longer life with its battery.and yet there's always 1 more question : If used in battery mode (standalone, no charging wire), does adding the PS100 make a difference, or just getting more battery power?
Great choice
Then you must always keep the A100TB on OFF and only turn on the PS100 pro (and recharge only its battery ).
I read on different sites A100TB+PS and Tsuranagi performances and sound signatures. What's your personal thoughts ?
Orphy for sale if interested. See classifieds.I'll bite the bullet and get the Orpheus with shielding. More than cost of the amp itself, but prob worthwhile. Thanks again.
Looks like I'm going the same route you did before. Getting the A100TB+PS100 soon, and somewhere down the road, experiment with op-amps. From your experience earlier, seems like V5id (input) and V6 Vivid (output) are the best combo. Obviously the lid can't be closedI advise you to add the power supply, because the sound performance of the A100TB gets a further improvement, as well as getting a longer life with its battery.
I haven't tried the other combinations. After reading various experiences of other people, I opted for the V5i D input and V6 Vivid output combination and the result is simply wonderful. And you have an ultra black background.Looks like I'm going the same route you did before. Getting the A100TB+PS100 soon, and somewhere down the road, experiment with op-amps. From your experience earlier, seems like V5id (input) and V6 Vivid (output) are the best combo. Obviously the lid can't be closed
If possible, can you share what I can expect from:
1) OPA1612AID - all stages
2) V5id - all stages
3) V5id - input stage only
4) v5id - output stage only
5) Combination of the above
Any noise issue with v5id as reported if using the PS100?
Thanks
