Originally Posted by markl
I think they say, "hey for $400, it's pretty good." I don't doubt that it is.
There are three types of audiophiles... The first type judges sound quality by how much the equipment costs. The second type judges sound quality based on charts and diagrams and numbers expressed in bits, kilohertz and decibels. The third type judges sound by how it sounds to his own ears. The first type ends up with a very expensive system that he is convinced sounds great. The second type ends up with a very complicated system that he is convinced sounds great. The third type ends up with a system that sounds great.
I think you are mis-informed, though, if you think they re-mix the 2-channel masters when they transfer them to SACD. The only time they re-mix is (obviously) for the multi-channel mix, or if the 2-channel original master tape is missing and all they have are the multi-tracks. But then again, if that's the case, they would have to re-mix it for a standard Redbook CD remaster, too.
That isn't true. That may be true of albums like DSOTM or Gaucho which were well mixed in the first place, but it isn't true of all SACDS. With many reissues of classic rock albums, they aren't going back to the original master mixdown... they're going back to the original master element reel... the two inch 24 track tape where each layer of sound was laid down separately. They're taking each element and rebuilding the mix using modern digital techniques.
Have you heard Let It Be Naked? That is *nothing* like either Phil Spector's mix, or the mix that the Beatles left behind when they abandoned the album. It's a totally new mix, built using digital multitracking instead of four track mixdowns; digital reverbs instead of reverberation chambers, wire reverbs or tape slaps; and completely different EQ settings. The Beatles never would have come up with that mix in a million years. That CD doesn't even sound like a Beatles album.
Now listen to some of the late sixties Rolling Stones tracks on SACD and compare them to the original pre-SACD album cuts. They're different mixes. The SACD has an overall cleaner sound, but it's lacking the punch and texture of the original mix. Jaggers' vocals are EQ'ed different and the wire reverb sound is replaced by a much wimpier digital reverb. Anyone who grew up listening to Street Fighting Man or Honky Tonk Woman has every nuance of that mix inscribed on the inside of their skull. You put on that SACD and old timers willl notice the difference in a second.
in general, you have a much better chance of getting a well-mastered SACD than you do of getting a well-mastered CD, that's been my experience.
Bingo! I agree with that. But that doesn't mean that the SACD format sounds better. That just means that the recording is mixed and mastered better. If they put the same care into mixing and mastering a regular CD, it would sound just as good.
I'm not saying SACDs don't sound good... I'm saying they don't sound *better* than a regular CD with the exact same mastering. To human ears, the higher sampling rate makes absolutely no difference, at least with analogue recordings. (I'll soon find out if it makes a difference with 192/24 recordings.)
Also, to respond to other recent points from other posters... You would be hard pressed to find higher quality sound than the Living Stereo releases from the late fifties. These are the albums that serious vinyl collectors pay hundreds of dollars to buy to play on their $20,000+ vinyl rigs. "Newer" does not mean "better sound". When properly engineered, analogue was just as capable of producing true audiophile sound as current technology. In fact, in a lot of cases analogue sound is better, because engineers were constrained by the comparitive inflexibility of the medium to keep recording techniques simple and direct.
anlogue 30ips DBX encoded and decoded master = 44.1/16 = SACD
See ya
Steve
