Monstieur
- Jan 3, 2017
The ADPCM algorithm is improved in aptX Adaptive, so you do get better quality at a lower bit-rate. However the latency of aptX Adaptive in low latency mode is still higher than aptX Low Latency. I believe the low latency mode still requires a dedicated antenna, so you will probably see it only in dongles and transmitters like the BT-W5. I'd like to see what latency LC3 can achieve without a dedicated transmitter.
