tharding247365
I'm low-key kinda tempted after using a Pixel for a few years nowPulled the trigger on the Xiaomi 15 Ultra and Buds 5 Pro. Need the latest Aptx Lossless and XPAN![]()
Thank you for the help.
Tried one more time to connect the DG60P to Homatics box. They pair but there is still no sound. The led on DG60P stays blue, I think it should be green if aptx adaptive is working? It is green on my laptop and tablet.
I gave up trying and ordered the Eppfun LE transmitter from aliexpress. Hope it works with the Edifier Stax S3.
I checked that there is a game mode on the Stax S3.
So I need to update the firmware directly when I receive the Eppfun transmitter?
Is there a way to see if the Stax S3 is receiving aptx adaptive codec? Is the blue led blinking whatever codec is in use?
Maybe there is a led on eppfun that shows what codec is in use?
Speaking of Eppfun, I did just order the Eppfun 3040 Pro Ultra transmitter as I want to be able to transmit LDAC and AptX adaptive from my PC to wireless IEM's or iFi Gryphon which I also have incoming. Don't know much about the company but complaints over in the FiiO BT11 thread put me off from that product. I also read that Eppfun will be releasing an app soon which would be nice. Will report back once the 3040 Pro Ultra arrives and I get a chance to test it.Asked eppfun if they have any plans or upcoming transmitters or dongles for Xpan, but they were pretty blunt with their No response.
Ill bug them with the same question after a few weeks, gotta keep on top of these slow companies.
Xiaomi fixed the issue with aptX Adaptive LE not available on 15 Ultra via a small sw update (Bluetooth framework update). Apparently they using whitelist approach and forgot to put 15 Ultra on the list. Whoops.Some behavior I have noticed:
+Change sample rate to 44.1kHz at 24 bit = aptX Lossless displayed in BT setting of Xiaomi phones (Xiaomi 12S Ultra "modded"/14 Ultra/15 Ultra)
+Change sample rate to anything else (default Adaptive/48/96kHz)= aptX Adaptive
+Cant enable aptX Adaptive LE 2.1Mbps at all on 15 Ultra. LE Mode in Xiaomi phone BT settings only show up LC3.
+Enable Wi-fi mode aka XPAN = aptX Adaptive R4 displayed on Xiaomi 15 Ultra. I also seen some screenshot of someone Xiaomi display aptX Adaptive 4.2M so this is strange?
Everything is updated to the latest. I will have to contact Xiaomi for answers.
The C81-PC is the best transmitter I found for my Bose QC Ultra earbuds, and I tried the BT-W6, the FMA120, and a couple of other Avantree products, and this was after no "full" Bluetooth transmitter was reliable; to be clear, by "best" I mean "the only usable transmitter". OTOH, my Intel AX200/210 PCIe cards work perfectly with my Airpods Max and other headphones, so the Bose are just really picky. I wrote a detailed message about them here:If anyone is looking for an Aptx Adaptive dongle for low latency, the Avantree C81 might be perfect. No audio cuts, no lag, sounds as good as the BT-W6 to my ears. I bought the console version, but it also perfectly on PC. (I recomend updating the firmware to the latest one)
EDIT: Forgot to say: there's also no 2-second delay for the sound to kick in, unlike the BT-W6.
O just recently got the Global Xiaomi 15 ultra and CN Buds 5 Pro Wifi. No issues here. I can use Wi-Fi and Aptx Adaptive LE R4 with no issuesXiaomi fixed the issue with aptX Adaptive LE not available on 15 Ultra via a small sw update (Bluetooth framework update). Apparently they using whitelist approach and forgot to put 15 Ultra on the list. Whoops.
The codec naming confusion also fixed now. aptX 4.2M is the definitive name.. If your Xiaomi 15 Ultra displays aptX Adaptive R4 name then it indicate you are running old sw.
As for the quality of Buds 5 Pro itself, it is decent for the price, bit worse than AirPods Pro 2 in both sound and ANC quality.
And Xiaomi said you need to buy proper regional version of Buds 5 Pro if you want to use it with your Xiaomi phone. Xiaomi phone running CN fw = need CN ver of Buds 5 Pro. Same with Global version, need both to be Global for proper behaviour.
Hi. Have anyone tried this device from eppfun? Is it any good?
eppfun Le Audio Aptx Lossless Bluetooth 5.4 Transmitter for TV/PS5, 96K/24bit Wireless Adapter with Encrypted Auracast LC3 Audio (8657 MAX2/AK8657 MAX2)
I think this is another version of the desktop transmitter that was mentioned here before.
Thanks for the useful information. I do like buttons for sure. I already have one BT transmitter without buttons (BT11) and it isn't good. But most likely not only because buttons.I did see this one around and it looks very similar to the eppfun LE BT transmitter, from quick look at the specs its still missing:
-BT codec buttons, LED lights to show what codec in play
-PC usb dac mode
-Antenna
-Mobile battery for portable use
-3 inputs only and lost the co-axial input jack
With out the ability to switch to aptx adaptive low latency or a led to show its even on that, I don't know how it will operate or how its latency performance will be for TV/Game use, it may just go to low latency mode auto like many others do.
It still has the issue of lack of dedicated power input or that usb jack is just the power input so it solves that issue.
Id just get the other one, miles better just update the firmware my review of its posted I think 1-2 pages back or in my signature.
