So my quick review of FMA120 + QCC5181 cable for GAMING (aptx lite) + mic (for discord) is just - dont do it. At least not with this cable
https://www.aliexpress.com/item/1005006160041908.html but i doubt others would work better.
Reasons:
1. Mic sounds really bad, although their marketing says 'Built-in HD Microphone Combined with Qualcomm aptX Voice (32kHz) + cVc10.0 Noise Cancelling Technology', it is just a noisy mono mic that sounds terrible.
2. Makes me sound like Megatron 2 meters away from my PC (and a a brick wall, yeah thats on me probably but still).
3. Mic volume is very low, and if i disable noise suppression on Discord (to boost the volume) the noise is very bad. Preamp in EAPO doesnt do much until like +5db and past that if you laugh or talk a lil louder it fries the other's ears.
4. Even standing in the chair like 40cm away from the FMA120 at times the sound starts to pop and need to disconnect/reconnect the cable to fix it.
Lossless works... effortlessly tbh if thats what you are into at least on the short period i tested it.
I think im done with wireless for some time, plug the cable back into the iems and buy a desk mic. Btw, i know that this isnt the topic for it, but if you can recommend some decent sounding budget one (that can be mounted on an arm) i'd appreciate it.
