tristanape
I was going to slot it till I seen the pins on the rear right where slot would need be.
It would be nice.... considering how almost no phones support it! I feel like AptX lossless is the ultimate vaporware. I mean it arrives but you cant use it except with a random dongle from a shady internet merchant.I wonder if they will sell a transmitter w/ AptX Lossless capability?
Perhaps. If / when my Indiegogo purchase of the Velacy Crystal 5A TWS and BlueBeam 3A arrives I can comment further if it's a hoax or a treat for the ears at a reasonable price. Nothing ventured nothing gained.It would be nice.... considering how almost no phones support it! I feel like AptX lossless is the ultimate vaporware. I mean it arrives but you cant use it except with a random dongle from a shady internet merchant.
As far as I understand, there's no way to change LE Audio codecs in developer options, so you're most likely using LC3. AOSP seems to only support LC3 at the moment, only Qualcomm's AOSP fork has aptX Adaptive.Under more dev settings, All BT codecs remain grayed out but LE audio is there but not can't be selected so its left on SBC, not that it matters since the Creative zens
actually inform you via the internal voice its connected to LE audio and the main BT menu shows LE audio is on also but would have been nice to compare codecs.
Maybe it was with A2DP? That "Bluetooth Audio Codec" option is actually only for A2DP codecs. Once again, AOSP only has LC3, probably this is the reason why Google haven't implemented this feature. With AOSP fork for Qualcomm SoCs and QCCxx7x/8x headset you could've get aptX Adaptive with LE Audio.Its an odd one, I do recall being able to flick between the codecs few months ago just can't recall how I did it.
Same as dev options, it can only change A2DP codecs, not LE Audio ones.There is an android app called BT codec changer but its not working with android14 so can't test it.
What r u testing firstMy Adapter arrived for the Intel BE200 (WIFI7/BT5.4) to change the Key type from A+E to E.
