O.K., so the TC28i adapter Lightning to usb-c will serve to deliver Hi-Res from my iPhone 7+ to my Parasound P6 Preamplifier's usb DAC input, is that right? I can buy this device on Amazon for about $28.
I don’t know the Parasound (looks cool from a quick google search btw.) but I am certain it will work. If not you have the perfect return policy by Amazon! I’d give it a try, it should work
Anyone else having issues with Apple TV 4k?
I can play on my IPhone or IPad or Macbook Pro without problems, can open the music app on Apple TV, browse content, can even play the radio stations but whenever hitting a play button for the actual streaming content, it won't play!
I tried reboot, checked logged in account etc, looking good...
All other content like Amazon Music HD or Tidal is working on Apple TV 4k...
Has anyone experienced random, high-pitched static in the middle of a song streaming from Apple Music? It was so loud I was afraid it had damaged my eardrums. It has happened a couple of times right in the middle of a song. It is very startling to say the least.
I think it may only happen when I use my phone as the source. I sometimes get audio dropouts when switching between apps while music is playing. I may have to start using my laptop instead of my phone.
It happened on my M1 MacBook Air a few times, but not frequent. It starts about 10 secs into the song. Good thing I don't listen that loud when it happens. =/
Do usb cables/adapters matter when trying to listen to 24/192?
I am using my iPad Pro as a source (with the hi res settings on), then a USB-C to usb a adapter, usb a to usb b cable, Topping D50s/A50s, 800S.
I’m only seeing 44.1 on the display and the only thing I can think of interfering with it is the USB adapter or cable. I haven’t found any info confirming this tho. I’m going to try iphone w ACCwith the same usb cable and perhaps a different cable to see if it stays the same. I will also try with my Mojo and hipdac to see if there are different results.
I don’t have the iPad Pro but was wondering if camera kit was still necessary and looks to be the case. So even if iPhone switched over to usb-c in the future, would still need it as well.
I just looked it up and the iPad Pro doesn’t need a camera adapter. Just direct usb-c should work. Only if port is lightning do you need adapter.
My 2021 iPad pro does not work with Audioquest USB-C DRAGONTAIL to AQ Cobalt or Red, it has to be the Apple CCK USB-C to USB-A then into either of the RED or the Cobalt. I haven't tried to a desktop DAC but will now.
I wouldn’t be surprised if Audioquest made the dragontail non-standard usb. They pretty much mess up everything. (I also once had dragonfly red & Dragontail…).
