Question on the high/low gain switch - my guess is that on the high gain setting nothing is actually happening, and that the low gain is just adding a resistor in series to increase circuit resistance for use with lower impedance headphones. If that’s the case, that would help me answer the question on whether to run on high at 40% or low at 80% for normal listening volumes. Anyone take a close look at the switch? I’m not ready to crack mine open quite yet.
Second question for folks who have switched out capacitors - has anyone hooked this up to a oscilloscope to see what the stock low-end frequency response within 3db is? I get how the coupling capacitor might be acting as a high-pass filter in this circuit, but wondering if we can put some real numbers on it. Mine seems to have pretty good low frequency response, as best I can tell it’s getting pretty far to the low-end of the range and I can’t detect any of the tell-tale signs of a diode thirsting for current when the bass drum thumps. Wondering if this was something done primarily by people powering speakers with this little guy?
Second listening session was Diver Down and by the time I got to Little Guitars (which is an excellent track) the amp was definitely warmed up and sounding great. A good record for checking out the range, in my opinion, because you have a lot of very loud things going on, sometimes all together, and sometimes not. Everything sounded very accurate and I got really nice clarity. I followed that up with 77, which is an excellent pop record but is the least demanding from a post-production/engineering/cross-fading/stereophonic standpoint of what I’ve listened to so far. That proved to be a good test in and of itself, as David Byrne’s range might be limited but his voice is distinct and was very well represented and clear, and sounded natural. Last record was The Bends, and while they certainly mellowed out and became much more prog/alt/art-rock with OK Computer, this is a record that is still very much guitar-god-alternative-grunge and yet uses production/engineering to move things around the sound stage. The amp again, represented things well and gave a nice, full-range, clear representation of the record.
So that’s probably it for posts using the stock tubes. They sound great, for what they are. I question if the 6N4 is the reason I hear discreet steps on certain highly engineered tracks like EXP on Axis: Bold as Love. It could also be that I’m not used to headphones and for the first time I’m hearing the hurried overnight work of Chas Chandler et al after Hendrix lost the side 1 master tape when he left it in a taxi. It only really showed up on that one track, which is admittedly the most demanding of what I’ve heard so far. I would say this whole tube amp thing is outrageously fun and new and exciting for me, and while I don’t think that’s clouding my judgement too much, I would also readily admit that I miss having many several thousand watts of multi-channel power shaking my whole house. We just moved, but in the old place it was a source of pride for my wife to come home and find that I’d popped another retrofit recessed light out of the ceiling with sonic power emanating from coils driving magnets shaking massive diaphragms. Oh well. Time to grow up anyway, right?
I’ve got reissue Genalex matched 6V6s and a 12AX7 on order and will keep rolling through the reissues I can get on Amazon Prime. From what I can see on there now, I can get matched 6V6s and a same-branded 12AX7 (or similar) from: Electro-Harmonix, Tung-Sol, Telefunken, JJ Electronics, Mullard, and Fender’s Groove Tubes (not really a reissue on that last one I guess...) One of the many reasons I settled on this amp was the ready availability of the reissued stuff. After that I might maybe possible start digging a hole in my wallet with some of the NOS options. The 1960s RCA 6V6G does look pretty rad, after all.
