- Mar 30, 2012
So you only upgraded the coupling caps?
More gains to be had with upgrade of the cathode caps.
What are the difference that upgrading each introduces? Just to recap ;3
I have just compared my best tubes for this amp (the russian tubes) with the 6BG6G (not the smaller narrow 6BG6GA) mm..6F6GT Great tube, good in all departments, good soundstage, forward presence
6BG6GA Same as 6F6 but more soundstage.
I must now agree this tube has just "dethroned" my best Russian tubes(!),Really all except the 6V6 were all enjoyable listening experiences, differences were not great but
I do think the 6BG6's are something special, certainly the best tubes I have come across
If you have ordered adaptors for the 6BG6 "G"s then I hope you have ordered them with longer external wires than normal.
The ones I got initially were only suitable for 6BG6 "GA"s. The ones I have on order now are 20mm
Oh, and as for the Dumont 6Q5G,
One died upon turn on so they were a bust.
Cathode cap increase output and all else cathode caps do, like increased gain, lower output impedance, but also add some nonlinearity.
This is done by stabilizing the voltage drop there.
It is usually minimally applied (for cost cutting and other reasons).
But for the output stage, increasing this cap to a larger value provides greatly needed benifit here with this tiny PSU,
by holding the cathode voltage constant, in relation to current demands, so the bias (in relation to the Cathode volt drop) is not dynamically changed by the music.
So the tube is kept at optimal gain.
So under more heavy dynamic loads, with its increased reserve capacity, it will not weaken so will sound stronger for more sustained power when needed like bass impacts and transients.
Unfortunately there is still sonic changes to be improved here as electrolytics are not sonically perfect, and thus have an indirect impact to sound im upper frequencies.
This is why many instances the cathode cap is paralleled with a smaller film cap for the higher frequencies.
I recommend the "Audio Note KAISEI" electrolytics,
As they supposed to be the best or closest to the legendary "blackgate" caps, which were highly regarded but not made anymore.
Then I use a paralleled bypass cap for the electrolytic,
A film cap of the exact same type/model/sonic signature cap as the coupling cap,
at an arbitrary low value anywhere from .047uf - .1uf max,
( from my experience with this amp and my bigger amp.)
To help the electrolytics with the upper end spectrum.
This is all only my suggestion, as there are obviously other opinions,
So hope this general info help clarify things.
I am glad you like them, I knew you would, LOL.I have just compared my best tubes for this amp (the russian tubes) with the 6BG6G (not the smaller narrow 6BG6GA) mm..
I have come to the exact same conclusion!
As they have the same level of liveliness, with slightly more depth and Soundstage,
Without sounding duller in the process which all the past larger sounding tubes did in comparison.
I am not sure which tube brand you have,
But after looking at the internals,
Amd based on my (weak ) experience,
I would go for the RCA triple Mica first,
Then the NU
Then the Tung-sol.
The newer RCA seem as the rest of them.
Who knows if they all sound as good, but the RCA & Acturus I have definitely sound above all the past powertubes I tried on this amp.
I do have a tung-sol trying next.
*Edit*
Yes the Tung-sol is tied with the pre1950 RCA (triple mica)
Those are the best although Haven't tried the NU or Ken-rad yet.
So Basically you just can't go wrong with any these old 6BG6G tubes...
They big yet gorgeous sound for this amp,
With similar strong output as the other best.
This is excellent news.
I didn't think it could get better in tube selection.
Yes mine have just enough length thanks.
Well I wonder then that since you have a different amp to the rest of us, that might be the reason the 12SL's work better for you?.
Previous experience with other amps I have found the 7/14 loctals perform better than the 6/12SL's. All the 14's have metal bases
so do not know if this is a factor. Mostly I have read that the metal based 6SL/N7 tubes are highly sought after.14/7 adaptors are inexpensive & the tubes will only set you back $7 or $8 a piece.
Just burning in my nos 14AF7 atm & waiting on the new adaptors for the 6BG6G's. The 6211 (12AT7 type) IMO is a totally underated/ignored tube
and deserves more respect (you can get GE 5 star 6211A's for $3 a piece). I did extensive tests over a long period of time in the past & these tubes outperformed all other 12AT7 types.
Of course we all like different types of sound but this one stood out for me personally.
Usually I don't have any opinions about RCA as they were always a normal bit unexceptionable tube in other types...I am glad you like them, I knew you would, LOL.
What this hobby/pastime is all about, enjoying better & better sound.
I have the RCA NOS tubes atm, will be getting some more but may be different brands, dont know until they arrive.
Mine are twin mica only.
So how would we introduce or solder in a smaller film cap in parallel bigger Kaisei's
But the older (1940s) triple mica 6BG6G RCA has the best internal structure of all of them and is different than the newer (1950s) RCA.
They perform on par with the Tung-Sol, which to me sound the best out of the 3 names I have in that type.
It was no surprise the Tung-Sol would be up there as one of best, but the old RCA is so impressive for RCA.
My setup is Bifrost 4490 + APPJPA1502a(with Jantzen Superior Z-cap)+HD600. The only power tube I have is JJ 6v6s. Initially I tried 12AT7 mullard, JJ 12au7 and 12au7 RCA clear top and was not happy. Thanks to @Maxx and @baronbeehive suggestions, I purchased GE 12SL7(silver round plate) , Tungsol 12SL7, Tungsol 5751(vintage) and JJ 12AX7. With my setup, IMO the GE 12SL7 treble sounds just a tiny bit harsh(probably due to HD600s sound signature), however the Tungsol 12SL7 is perfect, followed by Tungsol 5751. Also as @baronbeehive said the JJ12ax7(still burning in) sounds fantastic with this setup.
In essence I found my expectation bias was totally contradicted by the unexpected results.
After all tubes were burnt in I found the best driver to be the little 6211A. It pretty much wiped the floor
with the 12SL7 and although the 12SN7 performed better, the treble was distinctly inferior. Words that came to
mind at the time were splashy/tizzy/smudgy sss's sibilant. ............
