Originally Posted by user18 /img/forum/go_quote.gif Couldn't you just use a 1/4 to 1/2 inch adapter? ..
The weight of the 1/4" plug plus the adapter pulls down on the plug in whatever mobile device you are using. Ideal would be a low profile T-bend 1/8" plug like used in most IEMs.
Is the HD600 cable interchangeable with the HD650?
