shawn_low
- Aug 6, 2009
Hi all,
I did yet another silly thing: accidentally pumped 240V into a 110V Melos Maestro amp. GAH!
The amp was heavily modded by Fallen Angel on HF and his mods are detailed here: http://www.head-fi.org/forum/thread/...8-large-photos
The pictures on day 5 & 6 posts is the final configuration I am left with. Fallen Angel has schematics and also further technical details on the mod.
There was a pop sound. The fuse burnt out. I forgot to put the power through a step-down convertor.
I replaced the 250V fuse and put the power through a step-down convertor. It powers up. However, there is a low hum. I replaced the tubes and the hum is still there.
I sent pictures to Fallen Angel and he says that no caps or resistors look burnt out. The transformer seems OK (no sound nor is it overheating).
There are 4 LEDs that should light up (on the right side of the board). However, only the top three briefly come on before dying out. The fourth one doesn't even come on.
Fallen Angel said that that could be the cause of the problem and suggested I find someone local to look at it. He is in Canada and unable to look at it for a few months. He said it could be a burnt-out transistor and that this is probably the cause of the problem.
It works...music plays above the hum (and I can't hear the hum once the music is cranked up), but there certainly is something wrong with it.
Can anyone help look at it or direct me to a store which might look at it?
Also, would it be possible to replace the transformer to a 240V one? Fallen Angel says this "If you find a transformer that has the same secondaries, sure, but I doubt it's easy to find though and I'm not even sure of what secondaries it even has."
Should I still be using the amp?
Pics of the Melos after the damage are here:
LEDs in question are these ones:
I'm located in Australia but will accept all help.
Thanks in advance!
