Originally posted by Nik
My comparison between the two Stax drivers (717-007t) was incredibly clear: I do not like the "opamps" sound, I see the electrostatics cans more in the way of a very hi quality tube amp! |
It's difficult to say that transistor-based (whether opamp or discrete transistor -- opamps are "transistor blocks" that contain many transistors in a largely pre-made amplifier, whereas discrete transistors have each transistor separated out for the designer to control and tweak) amplifiers all have the same sound.
For example, a MOSFET-based Szerkes buffer with OPA2132 gain stage (which is a VERY, very simple design) design has been described as "bubbly hot tub warm", yet it uses an opamp and a single transistor. In fact, if your source has a volume control, you can leave out the opamp and have a single-transistor component, which is the ultimate in simplicity in audio design since, unlike tubes, all you need is a battery and a capacitor or two to drive it -- no transformers or complex power supplies or even more than a handful of resistors and a coupling capacitor or two.
Now, I'm not saying that the Szerkes buffer is terribly Hi-Fi (then again, I've never heard one, so I couldn't say!), but it is an example.
The KGSS and Blue Hawaii/Hybrid both use discrete transistors for gain, the Blue Hawaii uses grounded-grid EL34 tubes in its output stage. The grounded-grid is a technology that is almost unique in the world of audio, only one or two other designs in the world have ever used it. It was used a lot in radio, however, because of its excellent properties. In the Hybrid amplifier, the tubes give it a warmer quality with better bass (since the tubes have better control over the headphones) than the KGSS -- one person that built the Hybrid said that "if you aren't already a bass-lover, the Hybrid will make you one." Or something like that.
