dannyandelyse
- Feb 3, 2004
Tom...let me help you out. It is obvious you have to much equipment. It must be a real burden. I am sympathetic and am available to help you pack up Your HEV90 and those multitude OLD tubes that you cannot seem to settle down with a favorite one.
Let me lift your heavy burden...................
Dan
Originally Posted by bozebuttons Yes the HEV90 has a internal dac, a little outdated as it was made in the early 90s, it has coax, & optical inputs,doesn't sound to bad though,listened to it with the Theta basic feeding it when I first got it. Jimmy I am listening to the amp now & it is dead quite,I just rotated the volume control comlpletely quite,listening to Leonard Bernsteins West side Story with The HE90s sounds really good. I do have a differant tube compliment in the amp now then ones that was in the amp at the meet Mullard EL34s/12ax7 sylvainias as oppossed to the GE fatboy EL34 /12at7 combo that was at the meet. But I still had the problem even with the new tubes untill I flipped the switch on the phillips. I will have to put the HEV90 back in the system & flip the switch to see if the HEV 90 has any problems.It could have been the switch got flipped when I packed up the phillips at the end of the meet,I dunno. All I can say now is the singlepower amp is singing & is dead quite I am a happy camper right now listening to it. |
Dan
