Little wakeup for this.
I'm not positive on all the part numbers and values, here's what I figured (and got) for the latest schematic, please correct me if I'm wrong:
Please note right away that I will be using 2N5486 instead of 2N5484 which are rated at somewhat higher current. This is the diamond buffer:
The main thing is the 1K value of the source resistor R1/R4, R15/R16, R17/R18 - (same thing, different channel). I'm not positive if this is the correct value, but I'm thinking it is.
Also, for Class-A biasing of the opamp, I'll be using 1K for R10 (R10G, R10R & R10L) and most likely leaving the source resistor at 1K as well. Again, I'm kind of guessing here since I'm not positive on how to find the exact value of it.
Now, on to the parts list:
Power section
D1 : 1N4004
C1-C4 : Panasonic FM 560uF/35V
TLE : TLE2426ILP
C5-C6 : 4.7uF/63V Polyester Film
Diamond Buffers
PNP Input Transistors (T2, T6, T10) : BC327
NPN Input Transistors (T4, T7, T11) : BC337
PNP Output Transistors (Q5, Q6, Q4) : BD140
NPN Output Transistors (Q3, Q2, Q1) : BD139
CCS Transistors : 2N5458 & 2N5486
CCS Source Resistors (R1, R4, R15, R16, R17, R18) : 1K
Will be testing stuff until I get ~ 8mA out of the CCS
Output Emitter Resistors : 4.7Ohm
Input Emitter Resistors : 10Ohm
This will make the output current = CCS current x 2.1, looking for 15mA of output current - not sure why yet
Amplifier / Ground
Class-A CCS Source Resistors (R19, R20, R21) : 1K
Will be trying to Class-A bias the opamps to 5mA - hope that works well with OPA637s
Class-A Transistors : 2N5458 & 2N5486
R10G, R10R & R10L : 1K
R1R, R1L & R1G: 4.42K
R2R, R2L : 1M
R3R, R3L : 1K
R4R, R4L : 10K
R4G : 4.42K
R5R, R5L : Definitly SOCKET to tweak gain: Stock will be 3.32K for gain of 11.
R6R, R6L : 470K
C7 : 10pF C0G/NP0 Ceramic
Caps around OpAmps: 0.1uF X7R Ceramic
OPAMPS: Here, I'm trying out the OPA637/OPA627 for the first time
So for OPA637, gain will be pretty high, I'm thinking stock Pimeta gain of 11x. I'll socket one place to drop gain to 6 or 8 if it's stable, if not, I'll keep it at 11.
