- Aug 18, 2007
On another note - using my modded re-cabled D2000:
1) Comparing the iMod via built-in dock as source vs my CD/Apogee rig.
I use a Marantz CD5001 > Synergistic Research Active Powered Shielding COAX > Apogee mini-DAC > ALO SXC mini-RCA > the Amphora (basically $2000 source including cables and Sigma 11 PSU). Both were playing the exact same Diana Krall "Live in Paris" album. I used the volume pot on the Apogee to match the volume levels of the Apogee output to the iMod output levels. I had the two sources synchronized so well that there was NO discernable jump in the music when switching between the two sources.
The Apogee mini-DAC was slightly better in depth and detail and treble extension, but the iMod with lossless was impressively close. To the untrained ear some people would have denied any differences between the two sources. I can hear the differences (like maybe the Piano was slightly more forward with the iMod, and the Apogee was slightly more refined with the piano), but I was surprised at how well the iMod with Vcaps in the Amphora sounded vs the CD rig. My iMod cost $500 including the iPod, and plugged into the Amphora I would guess that it comes within 90-95% of the $2000 CD rig. (I know some people hate percentages, but it helps). Basically the iMod Vcap dock built into the Amphora is almost as good as the Jensen Copper Foil Cap iMod dock that I compared to the Apogee last year. To get a headphone amp into the dock for only a couple hundred more is impressive.
2) Comparing the Amphora single ended out of the Apogee mini-DAC vs the Single Power Square Wave XL balanced ($1249) via XLR out of the Apogee.
The Sq Wave was the amp I used to listen to the Jensen dock vs Apogee last year. So in this comparison I had both amps running at the same time out of the Apogee's SE and balanced outputs. I used my modded D2000 as before - with 4-pin XLR plug and the APS V3 4-pin to SE adapter in the Amphora, and plugged my APS V3 4-pin to dual XLR balanced adapter into the Single Power. I then matched the volumes of the two amps. I took the 4-pin jacks from the cable adapters into my hand, closed my eyes an mixed them up so I would not know which amp was which when I was listening.
I could not reliably pick which amp I was listening to. One time I thought one was more spacious and energetic and guessed it was the balanced amp but it was the Amphora. I mixed them up again and listened for that same sound, to tell the difference in the amps, and when I thought I was listening to the Amphora again I found it was actually the single power this time. They both sounded excellent, and too close to call.
With HD600 the advantage goes to the Sq Wave, especially balanced, but I wasn't kidding when I said the Amphora was a perfect match for the Denons. It was also a perfect match for the Edition 9, and if I hadn't sold the Ed 9 to help pay for my HD800 I'd be regretting the sale right now.
