I'll check it out, thanks!Check out the website AVforum, it's located in the UK, someone there might be able to point out the better deals in Europe.
Amp+dac or amp/dac for AKG 712 pro (first time buyer) ~230€ budget
- Thread starter leyo96
Edit to my list: Added xDuoo TA-01B and JDS Labs Element 1, clarified that the Topping DX3 pro is v2
The Element is a very nice amp I’ve heard it a few times but have never owned one or heard it with the AKG’s mostly planars but I’m sure it would have no problems with running them.
It's the element 1, not the 2 that they sell now. I can't find much regarding the original version or the difference between the two when I google it. Do you know the differences?The Element is a very nice amp I’ve heard it a few times but have never owned one or heard it with the AKG’s mostly planars but I’m sure it would have no problems with running them.
Yes I understood it was the 1 not 2 and I’m not sure of the difference either as I just heard the 2 at CanJam NYC in February and still think it is a good amp just like I thought about the original I’m pretty sure they changed the Dac in it but other than that I’m not really sure .It's the element 1, not the 2 that they sell now. I can't find much regarding the original version or the difference between the two when I google it. Do you know the differences?
https://blog.jdslabs.com/2019/11/jds-labs-element-ii-official-release-benchmarks/Yes I understood it was the 1 not 2 and I’m not sure of the difference either as I just heard the 2 at CanJam NYC in February and still think it is a good amp just like I thought about the original I’m pretty sure they changed the Dac in it but other than that I’m not really sure .
These are the differences, there's a performance comparison but I'm too much a noob to really understand. The dac is different and the amp is more powerful
While the Element 2 has better specs doesn’t mean the original Element is crap it just means they improved on it and I can’t say it sounds better as I don’t have both in front of me right now but I don’t think the guys at JDS Labs thought they made a crap amp with the original Element nor do I but technology has changed and components have changed and not always for the better but it got them to change some things to put out something new with better measurements. Look there is a lot of amps and dacs on the market right now and no one has heard them all and I’m just giving you my opinion of what I have heard not as much as some but more than most as I have been to 5 CanJams and over 30 local headphone meets but again it is only my opinion and rarely talk about something I have not heard or owned unless it is by someone I know and trust. Just my 2 cents.https://blog.jdslabs.com/2019/11/jds-labs-element-ii-official-release-benchmarks/
I trust what you say since you are more experienced than me and I'm giving a lot of value to what you said, thank you!While the Element 2 has better specs doesn’t mean the original Element is crap it just means they improved on it and I can’t say it sounds better as I don’t have both in front of me right now but I don’t think the guys at JDS Labs thought they made a crap amp with the original Element nor do I but technology has changed and components have changed and not always for the better but it got them to change some things to put out something new with better measurements. Look there is a lot of amps and dacs on the market right now and no one has heard them all and I’m just giving you my opinion of what I have heard not as much as some but more than most as I have been to 5 CanJams and over 30 local headphone meets but again it is only my opinion and rarely talk about something I have not heard or owned unless it is by someone I know and trust. Just my 2 cents.
I'm going to read some other suggestions just to have a bigger picture and then I'll decide
Edit to my list: Added Creative Sound BlasterX G6 at 160€, I could get a discount on the Beresford Caiman SEG, added a 10€ cheaper Topping D10 option but w/ longer shipping
- Aug 20, 2013
Also, check out the Topping A50:
https://www.amazon.it/gp/aw/d/B0823XGXZ1/ref=psdcmw_473377031_t3_B07ZNDN5PF
Nice 2.5mm-trrs-cable (MUST REQUEST FOR A 2.5mm-PLUG ON OR AFTER YOUR ORDER):
https://www.lunashops.com/goods.php?id=6904
It was already in my list.Also, check out the Topping A50:
Smart move as it’s your money not mine . I try to give the most honest impression of things that I can but always take what others say including me with a grain of salt because we all have different likes in dislikes in this crazy subjective hobby of ours. It’s always best to try something out first but I completely understand that is not always possible I’ve made a couple of blind purchases some have been great and others not so much. I wish you luck in the hunt though.I trust what you say since you are more experienced than me and I'm giving a lot of value to what you said, thank you!
Thank you, it's my first real purchase in the world of dacs and amps so I'm just a bit nervous because I'd like to get the best that I canSmart move as it’s your money not mine . I try to give the most honest impression of things that I can but always take what others say including me with a grain of salt because we all have different likes in dislikes in this crazy subjective hobby of ours. It’s always best to try something out first but I completely understand that is not always possible I’ve made a couple of blind purchases some have been great and others not so much. I wish you luck in the hunt though.
Edit: added LOXJIE D10 at 100€ from Amazon, found the Magni 3+ at 146€ from schiit UK instead of 178€ from schiit USA
