radlux
- Nov 7, 2008
Hi,
So I got my IBasso D3 python and I got it working fine. However the included documentation isn't the most detailed.
When I've connected to the laptop through USB I'm using output jack. The manual says something about using the input as a line out when using the USB. When I use it the amplifier is off.
Question 1:
So, when would I use this mode ? If I want to connect my laptop to an external amplifier and use only the DAC of the D3 ?
Question 2:
Are my AAA batteries being used when connecting to the input jack in this way ?
Question 3:
So in the normal case to use phones I should always be using the output jack ?
Question 4:
What does the red led light indicate ?
Question 5:
Does the gain switch do anything besides increase the volume when using the output jack ? I mean does it change the SQ ?
Sorry for the noob questions. Haven't used an ibasso before
Question 1:
Question 2:
Question 3:
Question 4:
Question 5:
