Geise
- Jul 4, 2004
Smoke and mirrors
Originally Posted by ayt999 I believe it works best if the headphone is plugged into the amplifier, and not having the headphone plug next to the CD12. |
Originally Posted by mbratrud They sure look comfortable....I'm sure someone else must have asked this already but I cqn't find it: IT looks as if there is a fitting that would allow for easy exchange of headphone cable (assuming you could get more of the fittings). Nik, Is the above right? If you got more of the fittings would the cable be screw on and screw off? In my opinion that would be a pretty cool design concept to allow for easy cable interchanges. |
Originally Posted by immtbiker Just like the Stax stand...I don't understand a company that puts out a stand that has only one part of your earpads making contact. Won't that eventually put a dent in the pad causing uneven contact with your head? Plus it must allow dust and dirt to fall into the pads openings. |
Originally Posted by Nik Rudi wrote (italian) a little rew about the Qualia 010/RP010 system (yes, he has the Qualia 010 too). I hope to translate it soon... but he thinks that this is the most neutral system today. He has examinated the Qualia 010 and he found right the specs that Sony has declared, just a pick in the 2 and 4 Khz of 1.5db . Best! Nicola |
