Thanks for the admission, about time!
G
G
Yes, exactly.....I meant standardized. Studios are not uniformly standardized across the world. Which would/could potentially mean tone changes with the final output.1. An objective measurement, a waterfall plot for example.
2. No, none at all! Double/Blind tests are only designed to test human responses but “fidelity” isn’t a human response, it’s a measurable, objective, physical attribute.
1. That’s complete nonsense, because fidelity is accuracy.
2. Of course you wouldn’t. For example, how would you get a speaker that can’t produce freqs below say 60Hz to accurately reproduce content between say 40-50Hz?
1. Countless studies by scientists and industry bodies (the ITU, EBU and AES for example). The 2000 paper by Geringer being just one example.
2. If you can give the exact opposite evidence, then please do so!
3. Your “claim” is NOT reliable evidence, surely you must know the difference between a claim and reliable evidence? And, popularity doesn’t prove people prefer “bassy/unbalanced sound” unless you eliminate other possible reasons for popularity, such as fashion for example.
4. You need to ignore yourself then! You think it’s “stable” to argue in a science forum when you don’t even know the difference between a claim and reliable evidence?
Of course it doesn’t, it’s guided and has concepts based on science, that’s why it’s called the sound science forum. Certainly there are people that don’t understand the science and certainly we all have ego but that is why science was invented in the first place! Do you really not know that?
Nonsense. The whole idea of fidelity is based on proven/demonstrable mathematics, as has been explained to you several times but apparently your ego only allows you to keep repeating the same nonsense!
Then either the books you’ve read are fantasy/fiction or you failed to understand them! All commercial studios are calibrated, they ALL measure the room/speaker response and they ALL apply corrective measures, acoustic treatment, EQ etc. However, in the case of music studios, there is no agreed standard of calibration. In other words, music studios typically calibrate to a “house curve” which may or may not be the same as the house curve of a different music studio.
G
That is somewhat true. Film and TV mix rooms are standardised, it’s only music studios that aren’t. However, in commercial music production it’s usual for the mix to be monitored on different setups, the main monitors and near-fields for example, commonly more than one studio is used for recording and mixing and of course the finished mix goes to another studio for mastering. These different setups and studios have the effect of averaging out (even’ing out) discrepancies that the FR of one studio might have caused.Yes, exactly.....I meant standardized. Studios are not uniformly standardized across the world. Which would/could potentially mean tone changes with the final output.
1. Why do I have to agree with that? ...[1] Still you have to agree there are many (different) end tones when it comes down to music reproduction. [2] That each album is it’s own thing, it’s own animal so to speak. This single thing is an example to me that there still is no true standardization in the industry.
True but then you never get to hear "how it's recorded", what you hear is not the recording, it's a processed mix of the recordings that has then been mastered! While different masters of different recordings/mixes all sound different of course, that's part of the creation process. It should be obvious that the reproduction process, by definition, is the process of reproducing what's been created, not of producing something else!Still stuff is all over the road as far as how it’s recorded.
1. There's nothing wrong with questioning the engineers' decisions, I do it frequently. The problem, particularly in the audiophile world, is that the guesses/answers they come up with are frequently wrong and not just wrong but often wildly/laughably wrong! For starters, some of the engineering decisions aren't actually made by the engineers, the engineers are just following instructions from the musicians, producer or record label and even when it is the engineers' decision, virtually without exception, they must be approved by the musicians and/or producer.[1] Obviously there are infinite variables in how bands are perceived to be recorded. But often (as we all do) I question the engineers decision or I just guess there was recording issues which could not be overcome, thus the result. [2] We all have our favorite recording engineers which have become somewhat of modern day legends. They have a particular sound, and use only a few studios to realize their craft.
How can that be true? Recording engineers are only responsible for recording the musicians' performances, what happens afterwards; the processing, mixing and mastering has nothing to do with the recording engineer that's the responsibility of others, the Producer for example.Hearing them make their (audio) statement time and time again is a example of maybe how it should be done (subjectivity speaking)? Though many times I will hear a new recording and love it, to then find out it was the production of (one of) these luminaries. Oh that’s what it is, I often say!
Extremely few music studios are standardised, even the ones which produce music for TV. There's not even a standard monitoring level for music studios.The music studios I've worked in were standardized. But they were producing music for both TV and CD. I would imagine that by the time the recording reaches the mastering stage, it would have to be calibrated.
That's a very common workflow, although it's also quite common to mainly mix on near-fields and then check on the big/main monitors. But again, while the main monitors are obviously calibrated, there is no standardisation. Different studios use different monitoring levels and have their own "house curve".When I mix, I always start with the big calibrated system. When that is done, we do a playback through small speakers to make sure nothing will blow out or get buried on a regular TV. We make corrections here and there and check them on the big speakers. When that's finished, the mix is done. The main speakers are used for the mix. The small ones are only used for checking the mix for problems. Maybe other people work differently.
Yep, he doesn't seem able to understand the difference between production and reproduction.I think redcar doesn't understand that the "many tones" of recordings are due to creative decisions in the mix, not to the way the equipment sounds. All of those tones are still calibrated.
2. There are in fact valid reasons why I have to agree with your #1, to a limited degree but NOT because of this statement! Obviously there is no standardisation for music composition, orchestration, performance, recording and production because if there were, then all pieces of music and recordings of pieces of music would sound the same. There would be little/no discernable difference between a Mozart symphony and say Motorhead's Ace of Spades, which clearly is not the case. However, while this #2 statement is true and so is your #1 statement, #2 does NOT support #1. There is no standardisation in the music industry as a whole but there IS a concept of standardisation in music reproduction ("fidelity"). Despite it being explained to you multiple times, you do no appear able (or willing) to understand the difference between music creation/production and music reproduction. A massive, fundamental misunderstanding for someone who discusses/argues about it so frequently! ...
2. I would imagine extremely few people even know the names of any recording engineers, let alone have favourite ones. Also, I'm actually in the industry and can't think of a single modern day legend, although several command significant respect.
G
2021 | Stand Amongst the Fallen | Mastering |
2013 | A Vanishing Day | Mastering |
1995 | As Tears (EP) | Producer, Engineering, Mixing |
2018 | The Only Pure Hate MMXVIII | Mastering |
2020 | Never Enough Snuff | Mixing, Mastering |
1993 | Obscuritatem Advoco Amplectère Me | Engineering |
1994 | In Umbra Malitiae Ambulabo, in Aeternum in Triumpho Tenebraum | Engineering |
2000 | De Profundis Mors Vas Cousumet (EP) | Engineering |
2015 | Grave Offerings | Mastering |
2020 | Accuser | Mastering |
2014 | Kult des Hasses | Mastering, Mixing |
2015 | Spreading the Plague | Mastering |
2012 | Temple of Marduk (EP) | Mastering |
2020 | The Negationist | Mastering |
2007 | Rise to Dominate | Mixing, Mastering |
2019 | Prokopton | Mixing |
2021 | A Dream of Wilderness | Mixing |
2009 | Cult of Sin | Mixing, Mastering |
2010 | Betrayed by the Gods (EP) | Mixing, Mastering |
2011 | Becoming the Martyr (EP) | Mixing, Mastering |
2012 | Dawn of the Enforcer | Mixing, Mastering |
2015 | Rejection Overruled (EP) | Mixing, Mastering |
2016 | Waves of Annihilation | Mixing, Mastering |
2017 | Restore to Sanity (EP) | Mixing, Mastering |
2010 | Decoding the Mainframe | Remixing, Remastering |
2017 | Zona de silencio XVII | Remastering |
2010 | Iraganeko bide malkartsutik | Mastering |
2012 | Complex Shapes | Mastering |
1996 | Hymn till hangagud | Producer, Mixing |
1991 | No Flesh Shall Be Spared (Demo) | Producer, Mixing, Mastering, Layout |
1992 | Ex Oblivione / The Fragile Concept of Affection (Split) | Mixing (tracks 1-7), Co-producer (tracks 1-7) |
2012 | Dark Domains (Compilation) | Producer, Remastering |
1996 | The Cainian Chronicle | Producer, Engineering, Mixing |
1999 | Det glemte riket (Compilation) | Co-producer (track 9) |
2012 | Into the Dark (EP) | Mixing, Mastering |
2014 | Echoes and Cinder | Mastering, Mixing |
2015 | Ancient Emblem / Hongo (Split) | Mastering (Hongo side) |
2021 | Distopia digital | Mastering |
2010 | Warfare | Mixing, Mastering |
2003 | Another Life (Demo) | Producer |
2008 | Memories from Nothing | Recording (drums, keyboards, lead guitars), Mixing, Mastering |
2010 | The Gothenburg Post Scriptum | Lyrics (track 3), Recording (vocals on track 3) |
2019 | Merciless Savagery | Mastering |
2013 | Aberration of Mind (EP) | Mastering |
2021 | Excess | Mastering |
2020 | Conjuring the New Apocalypse | Mastering |
2011 | The Consummate Ascendancy (EP) | Mixing, Mastering |
2020 | Ad Astra | Mixing, Mastering |
2015 | Dunkle Klänge | Mastering |
2017 | Black Path | Mastering |
2010 | Ars Subtilior from Within the Cage | Mixing, Mastering |
2014 | The Love Album - Volume I | Mastering, Producer, Mixing |
2015 | Gea (EP) | Mixing, Mastering (track 4) |
2009 | Death... The Brutal Way | Mixing, Mastering |
2012 | Deathhammer | Mixing, Mastering |
2016 | Incoming Death | Mastering, Mixing |
2017 | The Rack | Mastered for vinyl (LP2) |
2017 | The Rack | Remastering (CD2) |
(show all) |
2011 | Onyx | Mixing, Mastering |
2013 | Ritual Zombi | Mastering |
2013 | Revenant Wars (EP) | Mastering |
2015 | Altar of Disembowelment (EP) | Mastering |
2016 | Deathgeneration | Mastering |
2020 | The Third Perspective | Mastering |
2012 | In My Veins | Mixing |
2008 | Banished from Inferno (EP) | Mastering |
2011 | Minotaur | Mixing, Mastering |
2012 | In Darkness We Wait | Mastering |
2019 | I'll Swallow Your Soul (Single) | Mastering |
2009 | Our Twilight (EP) | Mixing, Mastering |
2010 | Curse of the Red River | Mixing, Mastering |
2012 | The Devil's Resolve | Mixing, Mastering |
2008 | The Last Alliance | Mixing, Mastering |
2011 | Doombound | Mixing, Mastering |
2018 | Blackened Call (Single) | Mixing, Mastering |
2019 | Pantheon of the Nightside Gods | Mixing, Mastering |
2013 | Infected Life | Mastering |
1996 | II (Demo) | Engineering |
2015 | Covered in Flies and Afterbirth | Mastering |
2022 | The Return of Lucifer | Mastering |
2003 | Ocularis Infernum | Mastering |
2021 | Frozen Dreams (Demo) | Remastering |
2021 | The Lonely Flowers of Autumn (Demo) | Remastering |
2000 | Breeding Death (EP) | Engineering, Producer |
2002 | Resurrection Through Carnage | Producer, Engineering |
2015 | Salvation by Bloodshed (EP) | Remastering |
2017 | Execution of Violence | Mastering |
2008 | Morning Wood | Mixing, Mastering |
2009 | 800 Miles | Mixing, Mastering |
2019 | Dreadlord | Mixing, Mastering |
2011 | The Cold Testament | Mixing (as "Dan Swano") |
2010 | Duh (EP) | Mixing, Mastering |
2013 | Sub stele | Mixing, Mastering (tracks 1-6) |
2015 | Nestrămutat | Mixing, Mastering |
2010 | Follow the Flames | Mixing, Mastering |
2014 | Unchained | Mastering, Mixing |
2017 | The Ichor Carcinoma | Mastering |
2018 | The Ichor Carcinoma (Instrumental) | Mastering |
2019 | Temple Graveyard (Single) | Mastering |
2020 | Embodiment of the Divine | Mastering |
2006 | Butchered Feast of Being (EP) | Mastering |
1993 | Dragons Dawn (Demo) | Recording, Mixing |
1994 | Floating Souls (Demo) | Recording |
2020 | Grotesque Macabre | Mastering |
2021 | Fiendish | Producer |
2018 | Chapel of Abhorrence | Mastering |
2017 | Malus Ascendant | Mastering |
2004 | Revel in Human Filth | Mastering |
2017 | Venomous Tongues (EP) | Mastering |
2018 | Empyrean Atrophy (EP) | Producer |
2020 | Ceremonial Resurrection (EP) | Mastering |
2019 | The Last Day on Earth | Mastering |
1994 | Transcend the Dark Chaos (EP) | Producer |
1996 | Malleus Maleficarum | Producer (tracks 4-7) |
2010 | Chalice of Black Flames (Demo) | Mastering |
2010 | Chalice of Black Flames (EP) | Mastering |
2010 | Black Oblivion | Mastering |
1997 | Forever Dead | Engineering, Mixing |
1998 | Delete | Editing |
2021 | Human Erase | Mastering |
2013 | Cold Colours | Mastering |
2014 | MMXIV (EP) | Mastering |
2017 | A Life Forlorn (Single) | Mastering |
2019 | Northernmost | Mastering |
2017 | Sieben | Mastering |
2006 | The Contaminated Void | Mixing |
2007 | Pig Destroyer / Coldworker / Antigama (Split) | Mixing |
2008 | Rotting Paradise | Mixing, Mastering |
2009 | Coldworker / Deathbound (Split) | Mixing, Mastering |
2012 | The Doomsayer's Call | Mastering, Mixing |
2014 | The Coffin Earth's Entrails | Mastering |
2011 | The Bottom Deep | Mastering |
2021 | In the Darkest of Times | Mastering |
2021 | Konvergenz (Split) | Mastering |
2014 | Starlit Flame (EP) | Mastering |
2015 | Neptune | Mastering |
2017 | Sol | Mastering |
2015 | Toxic Waste Blues | Mastering |
2021 | Hategod Triumph | Mastering |
2013 | In Strange Aeons... | Mastering |
2006 | Terra | Mastering |
2017 | Wherever They May Rot | Mixing, Mastering |
2019 | Espíritu de lucha | Mastering |
2009 | Crowns for Kings | Mastering |
2013 | The Wakening | Mixing, Mastering |
2017 | Reality Illusion | Mixing, mastering |
2010 | All Roads Lead to Death | Mastering |
1994 | Dark Funeral (EP) | Engineering, Mixing, Producer |
2002 | Under Wings of Hell (Split) | Producer |
2013 | The Secrets of the Black Arts | Engineering (CD 2) |
2017 | The Rejects (Single) | Mastering |
2019 | The Rejects | Mastering |
2020 | Mister Babadook (Single) | Mastering |
2017 | Blightingales | Mixing, Mastering |
2020 | Kingdom of Decay | Mastering |
1991 | Dark (Demo) | Recording, Mixing |
1992 | Sleep Forever... (EP) | Producer, Mixing |
1995 | A Dance on the Grave (Compilation) | Engineering |
2012 | Cthulhu Riseth - The Complete Works of Darkified (Compilation) | Mastering, Liner notes |
2009 | Fear Yourself | Producer, Mixing, Mastering |
2016 | Delirious Excursion | Mastering |
1992 | Apparition (Demo) | Engineering, Recording |
1993 | Promotional Demo (Demo) | Engineering, Recording |
1994 | Nær sólen gar niþer for evogher | Engineering, Mixing, Remastering |
1994 | The Dark Light / The Eternal Forest (Split) | Engineering, Mixing |
2014 | The Eternal Forest - Demo Years 91-93 (Compilation) | Remastering |
2014 | Slaughtersun (Crown of the Triarchy) | Remastering |
2017 | Ascension Gate | Mixing, Mastering |
2012 | Angel Eyes (Single) | Mixing, Mastering |
2014 | Life Denied (EP) | Mastering |
2013 | The Clockwise Charade | Mixing, Mastering |
2016 | Descend into Madness | Mastering |
2021 | The Brightest Light (Single) | Mastering |
2020 | Grave Image | Mastering |
2010 | The Vanishment and Extermination of the Deities | Mastering |
2013 | The Perishing Empire of Lies | Mastering |
2014 | Arcane Impurity Ceremonies | Mixing, Mastering |
1996 | Abrah Kadavrah | Recording (as "Dan "Noseghost" Swanö") |
2016 | One Day More, One Day Less | Mastering |
2019 | Against Tyranny | Mastering |
2019 | The Fall | Mastering |
2007 | Breath of the Demiurg | Mastering, Producer, Mixing |
2008 | The Hate Chamber | Mixing, Mastering, Producer |
2010 | Slakthus Gamleby | Mixing, Mastering |
2009 | Catacombs of the Grotesque | Mastering |
2016 | Those Who Beheld the End | Mastering |
2013 | Scorched Earth | Mastering |
2015 | Intravisceral Exhibition (Split) | Mastering (track 3) |
2019 | Anathema | Mixing, Mastering |
2012 | My Empire | Mixing, Mastering |
2014 | Kingdom of Worms | Mastering, Mixing |
2017 | Dead Shores Rising | Mixing, Mastering |
2019 | Shareholder of crap (EP) | Mastering |
2020 | Songs of Love in the Age of Anarchy (EP) | Mastering |
2009 | Promo 2009 (Demo) | Mastering |
2012 | Invasion | Mastering |
2011 | Bitterness | Remastering |
2011 | Into Eternity | Remastering |
1998 | Innoscent | Mixing, Mastering |
2015 | Intermination | Mixing, Mastering |
1996 | Ravendusk in My Heart | Producer, Engineering, Mixing |
1997 | The Phantom Lodge | Producer, Engineering, Mixing |
1998 | Nightwork | Producer |
2001 | Death's Design - Original Motion Picture Soundtrack | Editing, Producer, Mixing |
2015 | Out of the Ashes | Mixing, Mastering |
1995 | Awaiting the End (EP) | Producer |
1993 | The Somberlain | Engineering |
1995 | Storm of the Light's Bane | Engineering |
2019 | Let the Death Enter | Mastering |
2012 | Dimension: Death | Mastering |
2016 | Reborn | Mastering |
1993 | A Shadowed Path of Dreams (Demo) | Engineering, Mixing |
2020 | Thunder in the Mountains | Mastering |
2021 | The Sachem's Tales | Remastering |
2013 | Necrogod | Mastering |
2006 | Harmony of Lies | Mixing |
1991 | Nothing but Death Remains | Mixing (as "Dan") |
1992 | Unorthodox | Mixing |
1993 | The Spectral Sorrows | Engineering, Mixing |
1994 | Purgatory Afterglow | Engineering |
1996 | Crimson | Engineering, Mastering, Editing, Cover art concept |
2003 | Crimson II | Producer, Engineering, Mixing, Songwriting |
(show all) |
2012 | Coma Ghosts | Mixing, Mastering |
2021 | No More Remorse | Mastering |
2019 | Under the Sign of a Black Star (Single) | Mixing |
2019 | Silverseal (Single) | Mixing |
2019 | Divination (Single) | Mixing |
2019 | Reader of the Runes - Divination | Mixing |
2021 | The Moon and Magic (Single) | Mixing |
2016 | Among the Shadows (Compilation) | Mixing, Producer, Recording (tracks 1-4) |
2021 | Lang kald natt | Mastering |
2010 | Tales from the Morgue | Mixing, Mastering |
2011 | The Tomb Awaits | Mixing, Mastering |
2013 | Raging Death | Mixing, Mastering |
2015 | Obliteration | Mastering, Mixing |
2017 | World Inferno | Mixing, Mastering |
2019 | Rise of the Reaper | Mastering, Mixing |
2009 | Adou Katavasis (Single) | Mastering |
2011 | Descensus ad Inferos | Mixing, Mastering |
2017 | Mære (EP) | Mastering |
2012 | The Shortest Way | Mixing, Mastering |
2010 | III | Mixing, Mastering |
2021 | Cleopatra | Mixing, Mastering |
2013 | Excised and Anatomised (EP) | Mixing, Mastering |
1998 | Dreaming the Reality | Mixing, Producer |
2011 | Fairytale of Perversion | Mixing, Mastering |
1997 | Seas of Eternal Silence | Producer, Engineering |
2009 | Withdrawal | Mastering |
2007 | The Crossfire | Mixing, Mastering |
2019 | Upon the Throne of Baphomet (Demo) | Mastering |
1995 | Myst | Mixing, Engineering |
2018 | Tales of Hate, Lust and Chaos | Mixing, Mastering |
1994 | Impurity | Producer, Engineering, Mixing |
2013 | Make Your Own | Mixing, Mastering |
2013 | Beyond the Self | Mixing, Mastering |
2018 | The Light That Shines | Mixing, Mastering |
2012 | The Art of Coming Apart: Chapter V | Mastering |
2013 | Smile as You Kill | Mastering |
1992 | Through Fire (Demo) | Recording |
1993 | Promo 93 (Demo) | Recording |
2013 | Humanity's Dirge (Compilation) | Recording (tracks 1.5-1.12) |
2011 | Reduced to Sludge | Mixing, Mastering |
2015 | The Black Death (EP) | Mixing |
2019 | Crowned and Reborn | Mastering |
1997 | The Dawn of Flames | Mixing, Engineering, Songwriting (keyboards) |
2002 | The Dawn of Flames / At Dusk and Forever (Compilation) | Mixing (disc 1), Engineering (disc 1), Songwriting (keyboards) (disc 1) |
1995 | Frozen in Fire | Producer, Mixing |
1997 | Black Box | Producer |
2017 | Glioblastoma (Demo) | Mastering |
2013 | The Warrior's Code | Producer |
2014 | Ocean Blade | Mixing |
2014 | Beyond the Veil of Flesh | Mixing, Mastering |
2017 | The World Ablaze | Mixing |
1994 | Demo-94 (Demo) | Producer, Recording |
1996 | Sea of Dreams | Producer, Mixing |
1996 | Shadow's Dance | Recording, Editing |
2001 | Sea of Dreams / Shadow's Dance (Compilation) | Producer, Recording, Mixing |
2012 | Weltenschmerz | Mastering |
1993 | As the Shadows Fall | Producer, Mixing |
1995 | In the Electric Mist | Producer, Engineering, Mixing |
1997 | A Wayfarer's Tears | Producer, Engineering, Mixing, Songwriting |
1996 | Eternity: The Weeping Horizons | Engineering |
2008 | Misotheism | Mastering |
2010 | MXCII | Mastering |
1991 | Human Relic (Demo) | Mixing, Producer, Engineering, Recording (as "Day DiSyraah") |
1991 | Obsequies... (Demo) | Producer, Recording, Engineering, Mixing |
1992 | Into Shadows (EP) | Producer, Recording, Engineering, Mixing |
2012 | Within the Shadow of Darkness - The Complete Recordings (Compilation) | Mastering |
2012 | Bow Down Before the Blood Court | Mixing, Mastering |
2014 | Imperial Anthems No. 15 (Split) | Mixing |
2018 | Open Casket, Open Mouth (Single) | Mixing |
2019 | Maniacal Viral Infestation (EP) | Mixing, Mastering |
2021 | Spectral Carnage | Mixing, Mastering |
2009 | One with the Dead | Mastering |
2020 | Cold Dead Lands | Mastering, Mixing |
2009 | In Aloof Lantern, Thy Bequeathed a Wailer Quietus... | Mixing, Mastering |
1990 | Dead Tales (Demo) | Recording |
2018 | Concealed in the Shadow | Mastering |
2014 | Leap of Faith | Mixing, Mastering |
2015 | Inhabitants of Carcosa | Mastering |
2007 | Hail of Bullets (Demo) | Mixing |
2008 | ...of Frost and War | Mastering, Mixing |
2009 | Warsaw Rising (EP) | Mixing |
2010 | On Divine Winds | Mastering, Mixing |
2013 | III: The Rommel Chronicles | Mixing, Mastering |
2009 | World of Ruin | Mastering |
2014 | A Serpent in Judecca (Single) | Mastering |
2021 | Masks | Mastering |
2018 | A False Reality | Mastering |
2010 | The I-Conception | Mixing, Mastering |
1992 | Sick Jar of Jam | Producer |
1992 | Promo Tape 1992 (Demo) | Engineering, Mixing |
2010 | Coils of a Consumed Paradise | Mastering |
2013 | Epilogue of Masquerade | Mastering |
2006 | In These Veins | Mixing |
2009 | Single Ticket to Paradise | Mixing |
2017 | Heathenspawn (EP) | Mastering, Mixing |
2016 | The Great Void of Mystery | Mastering |
2012 | Aikakirjat | Mastering |
2018 | Hybrid Cognition (EP) | Mixing, Mastering |
2012 | Das Atmen der Erde | Mixing |
2018 | Flesh & Bones | Mastering, Mixing |
2016 | Sandstorm Chronicles | Mastering |
2021 | Unholy Graves (Single) | Mixing, Mastering |
2021 | From the Sulphur Depths | Mixing, Mastering |
2018 | Sin | Mastering |
2012 | The Deathcult pt. I: An Oath in Darkness (EP) | Mixing, Mastering |
2010 | Defoulment of Human Purity | Mastering |
2020 | Hard to Stop | Mixing, Mastering (as "Dan") |
2015 | In the Fields They Bled | Mastering |
2019 | Doedsformasjon | Mastering |
2013 | Mayan Logic | Mastering, Mixing |
2010 | Fractal | Mixing, Mastering |
2012 | Odd Ethics (EP) | Mixing, Mastering |
2015 | Prodromes of a Flatline | Producer, Engineering |
2015 | Devianz - Dem Menschen ein Wolf | Mastering |
2001 | 10 Years of Chaos and Confusion (Compilation) | Engineering |
2004 | The Arrival | Lyrics (tracks 1, 3, 4, 7-9) |
2013 | Chronicles | Mastering, Mixing |
2014 | Opus of the Obliterated | Mastering |
2019 | Reveal Your Soul for the Dead | Mastering, Mixing |
2015 | And Thus We Raid | Mastering |
2007 | For Tyrant's Sake | Mastering |
2007 | Curse of Devastation (EP) | Mastering |
2012 | Degeneration (Single) | Mixing |
2012 | Vanquish in Vengeance | Mixing, Mastering |
2014 | Dirges of Elysium | Mixing, Mastering |
2016 | XXV (Compilation) | Mixing, Mastering |
2017 | Rotting Spiritual Embodiment (Live album) | Remastering |
2017 | Profane Nexus | Mixing, Mastering |
2020 | Sect of Vile Divinities | Mixing, Mastering |
1991 | Perverted Possessions (Demo) | Mixing (as "One and Only Explorer of Sadistic Nasal Sex") |
2009 | Seasons in Equilibrium | Mastering |
2021 | Dead Aesthetics | Mastering |
2021 | Psychosis | Mastering |
1996 | Killing Christ (EP) | Producer, Engineering |
1997 | Hell**** | Engineering, Producer, Mixing |
1999 | JesuSatan | Composition, Arrangements, Lyrics (track 2), Recording, Mixing |
2007 | Darkcide / Infestdead (Split) | Producer |
2016 | Satanic Serenades (Compilation) | Remastering |
2015 | Aembers (EP) | Mastering |
2016 | Winter's Gate | Mastering, Mixing |
1992 | Forward to the Unknown (Demo) | Engineering, Producer, Mixing |
1994 | The Final Chapter (Demo) | Engineering, Mixing, Producer |
2010 | Where Death Will Increase 1991-1994 (Compilation) | Producer |
2020 | Shieldbrother | Mastering |
2018 | Jungle Rot | Mixing, Mastering |
2015 | Cause the War Never Ends... | Mastering |
2011 | Veni Vidi Vomui | Mastering |
2011 | Starving Death | Mixing, Mastering |
2015 | Torment | Mixing, Mastering |
2001 | Sbrodj (EP) | Recording, Mixing |
2015 | Exile | Mixing, Mastering |
1992 | Jhva Elohim Meth (Demo) | Producer, Engineering, Mixing |
1993 | Dance of December Souls | Producer, Engineering, Mixing |
1995 | For Funerals to Come... (EP) | Recording, Engineering, Mixing |
1996 | Primordial / Katatonia (Split) | Mixing, Producer |
1996 | Brave Murder Day | Engineering, Mixing |
1998 | Saw You Drown (EP) | Producer, Engineering, Mixing (track 4) |
2003 | Viva Emptiness | Editing (additional) |
2019 | Multi Dead World | Mastering (as "D. Swanö") |
2017 | Kemwer | Mastering |
2018 | :Macht:Missbrauch: (EP) | Mastering |
2021 | Dödens Dal (EP) | Mastering |
2009 | Gospel of the Wretched | Mixing, Mastering |
2012 | Ad Bellum (EP) | Mastering (tracks 1.1-4) |
2019 | Realm of the Banished Gods | Mastering |
2011 | Legacy of Emptiness | Mixing, Mastering |
2017 | Over the Past | Mixing, Mastering |
1994 | Grey-Flannel Souled | Engineering, Mixing, Lyrics (tracks 3, 6) |
2012 | Love | Mastering, Engineering |
2007 | Into the Deep (Demo) | Mastering |
2013 | Bay of Kings | Mixing, Mastering |
2015 | Eternidad solemne | Mastering |
2020 | The Faustian Winter | Mastering |
1993 | Promo 1993 (Demo) | Mixing, Recording |
2019 | El retorno a la obscuridad (EP) | Producer |
2015 | Under the Fig Tree | Mastering, Mixing |
2010 | Close to Eternity | Mastering |
2015 | Dead Man's Path | Producer, Mixing |
2019 | Release the Soul (Single) | Mixing, Mastering |
2019 | The 13th Beast | Mixing, Mastering |
2012 | Soil | Mixing, Mastering |
1992 | Mind (Demo) | Producer, Mixing |
1991 | **** Me Jesus (Demo) | Mixing |
1992 | Dark Endless | Mixing, Engineering |
1993 | Those of the Unlight | Mixing |
1994 | Opus Nocturne | Engineering, Mixing |
1995 | **** Me Jesus (EP) | Mixing |
1997 | Here's No Peace (EP) | Engineering, Mixing |
1999 | Those of the Unlight / Opus Nocturne (Compilation) | Engineering, Mixing (tracks 9-17) |
2017 | Soul Deception | Mixing, Mastering |
2021 | Resurgence | Mixing, Mastering |
2017 | Until Time Has Lost All Meaning (EP) | Mastering |
1997 | The Force | Producer, Recording, Mixing (as "Dan "Fire****" Swanö") |
2004 | Brave the Blizzard (Single) | Producer |
2016 | Solipsism | Mastering |
1994 | Blessed Are the Dead (EP) | Producer |
2013 | Doomain | Producer, Mixing, Mastering |
2021 | 1349 | Mixing, Mastering |
1994 | Unbound | Recording, Mixing |
2013 | Unholy Black Splendor | Mixing, Mastering |
2011 | Reverence | Mastering |
2021 | The First Line (Single) | Mastering |
2018 | Becoming (EP) | Mastering, Mixing |
2010 | Imminent Chaos Complete | Mastering |
2018 | I Disavow (Single) | Mastering, Mixing |
2008 | Catalogue of Carnage | Mixing, Mastering |
2014 | Nocturnal Bloodshed | Mastering, Mixing |
2009 | Doom with a View | Mastering |
2009 | Blod-draum (Compilation) | Mastering (Disc 1: tracks 1-14) |
2017 | Alternātum | Mastering |
2018 | Scale and Probability | Mastering |
2012 | Violence, Fraud, Treachery | Mixing, Mastering |
2021 | Dress Code: Blood | Mastering, Mixing |
2018 | Immoral Blasphemies | Mastering |
2007 | Metamorphose | Mixing |
2012 | Cursed to Live (Live album) | Mixing |
1992 | Gospel of Gore (Demo) | Producer, Mixing, Engineering |
1994 | In Articulo Morti (Demo) | Mixing, Recording, Producer |
1995 | Tusen år har gått... | Engineering, Mixing |
2012 | Deathlike Thrash 'n' Roll | Mastering |
2021 | In Somber Dreams (EP) | Mastering |
2014 | Electric Revelation | Mixing, Mastering |
2018 | King Collider (Single) | Mixing, Mastering |
2018 | Re-Ignite (Single) | Mixing, Mastering |
2018 | The Damage (Single) | Mixing, Mastering |
2018 | Race to Resurrection | Mastering, Mixing |
2021 | Dead Rising (Single) | Mixing, Mastering |
2021 | Hellbreaker (Single) | Mixing, Mastering |
2021 | Car Wars (Single) | Mixing, Mastering |
2021 | Hellbreaker | Mixing, Mastering |
2011 | MyGrain | Mixing, Mastering |
2013 | Planetary Breathing | Mastering, Mixing |
2013 | Moloch | Mastering |
2020 | Cerecloth | Mastering |
2018 | Gaimald | Mastering |
1993 | Who Shares the Guilt? / Blind World (Split) | Engineering |
1996 | Fuego y Azufre! / Smile When You're Dead (Split) | Recording (tracks 6-13) |
1998 | Inhale / Exhale | Editing, Pre-Mastering |
2000 | Human 2.0 | Editing |
2014 | Lex Talionis (EP) | Mastering |
2017 | Those Who Belong to the Mist | Mixing, Mastering |
2019 | Ceremonies for the Dead | Mixing, Mastering |
2017 | Que muera el perro Jesús!!! (EP) | Mixing, Mastering |
2020 | Into the Gloom of the Buried Valley | Mastering |
1991 | Severe Malignant Pustule (Demo) | Mixing, Engineering |
1991 | Mucu-Purulent Miscarriage (Single) | Recording, Mixing |
1993 | Pathological Performances | Mixing, Engineering |
1994 | Promo Tape '93-'94 (Demo) | Recording, Mixing |
1994 | Necronycism: Distorting the Originals (EP) | Engineering |
2020 | No Living Man Is Innocent | Mastering |
2019 | Into the Vast Uncharted | Mastering |
2019 | Conjure the Storm | Mixing, Mastering |
2011 | Five Scars | Mixing, Mastering |
2018 | The Last Sunsets | Mixing, Mastering |
2020 | Dawnlight Garden | Mixing, Mastering |
1995 | The Breathing Shadow | Recording, Mixing, Cover concept |
1996 | The Closing Chronicles | Engineering, Mixing |
2000 | I | Engineering |
2003 | Alive Again: The Breathing Shadow Part IV | Engineering, Mixing |
2004 | Invisible | Producer, Recording, Mastering, Mixing, Engineering |
2005 | Nightfall Overture | Mastering, Engineering, Mixing |
2007 | White Darkness | Engineering, Mixing, Mastering |
2014 | Retribution | Producer, Mixing, Mastering |
2017 | Rock Hard Live (Live album) | Mixing, Mastering, Cover art, Layout |
2016 | Deathless and Fleshless | Mastering |
2018 | The Burning Silence | Mastering |
2007 | Terra Necrosis | Mastering (track 11) |
2008 | Legiões em Portugal (EP) | Mastering |
2020 | In a Pallid Shadow | Mastering |
2017 | Myrrys | Mixing, Mastering |
2005 | The Pale Haunt Departure | Mixing |
2007 | The Novella Reservoir | Mixing |
2009 | Into Night's Requiem Infernal | Mixing, Mastering |
2011 | Aphotic | Mixing, Mastering |
2014 | Bled White | Mixing, Mastering |
2017 | Hamartia | Mixing, Mastering |
2019 | Nephilim Grove | Mastering, Mixing |
1994 | Wish I Could Dream It Again... | Recording |
1996 | Arte Novecento | Mixing, Recording |
2016 | Ursa | Mastering, Mixing |
2016 | Annoluce (EP) | Mixing, Mastering |
2019 | Darkness Must Prevail | Mastering, Mixing |
2021 | The Pattern | Mixing, Mastering |
2020 | Oceans of Slumber | Mixing, Mastering |
1997 | Rain Without End | Producer, Engineering |
2008 | Rain Without End | Remastering |
2009 | Rain Without End | Remastering |
2010 | Rain Without End | Remastering |
2012 | The Treachery of Senses | Mastering, Mixing |
1999 | Odyssey (EP) | Producer |
2010 | Reinventing the Past | Producer, Mixing, Mastering |
2021 | Decrepitus | Mixing, Mastering |
2008 | The Redshift | Mixing, Mastering |
2011 | New World Shadows | Mixing, Mastering |
2013 | Beyond | Mixing, Mastering |
2015 | Skyline (Single) | Mixing, Mastering |
2016 | Grey Heavens | Mastering, Mixing |
2018 | The Burning Cold | Mixing, Mastering |
2018 | Aegean Sorrow | Mixing, Mastering |
2020 | Threnos | Mixing, Mastering |
2013 | Ritos diabólicos | Mixing, Mastering |
1995 | Orchid | Producer, Engineering, Mixing |
1996 | Morningrise | Producer, Engineering, Mixing |
1994 | A Journey in Darkness | Producer, Engineering |
1995 | Via Dolorosa | Engineering |
2015 | The Burden of Man (Single) | Mastering |
2010 | Adversary (EP) | Mastering |
1994 | Tears of the Society (Demo) | Producer |
1993 | Threshold to Reality | Producer, Engineering |
2002 | Dead Unburied | Mastering |
2003 | Murder Death Kill | Mastering |
2004 | No Divine Rapture | Mastering |
2005 | Deadbanger / Promoting Total Death / Dead Unburied / Warlust (Compilation) | Mastering |
2006 | Untitled / Chapel of Blood (Split) | Mixing |
2009 | Basic Instructions for Dying (Compilation) | Mixing (track 3) |
2012 | Carve: Stillborn Revelations and Revel in Filth (Compilation) | Mastering (tracks 14-20) |
2001 | Shut Your Mouth (Single) | Engineering |
2002 | Just Hate Me (Single) | Engineering |
2002 | Eleanor Rigby (Single) | Engineering |
2002 | Nothing Remains the Same | Engineering |
2005 | Nothing (Single) | Co-producer |
2014 | Falling Home | Mastering |
1993 | Khaooohs | Recording, Mixing |
1996 | Khaooohs & Kon-fus-ion | Producer (as "Day DiSyraah") |
2014 | Rotting Immortality | Mastering |
2015 | The Dysentery Penance (Compilation) | Remastering |
2016 | Reflections of the Mind (Compilation) | Remastering |
2017 | Hypnotic (Single) | Mastering |
2018 | Hadeon | Mastering |
2016 | First Commandment (EP) | Mastering |
2018 | Cause and Effect (EP) | Mastering |
2021 | The Powers That Be | Mastering |
2020 | Pile of Priests | Mixing, Mastering |
2012 | The Download EP (EP) | Mixing, Mastering |
2014 | For All That Is Damned to Vanish | Mastering |
1998 | Stalemate | Producer |
2010 | Signs of Nine | Mastering |
2009 | Human Machine (EP) | Mastering |
2016 | Pulse of Nebulae | Mastering |
2017 | The Empires of Death (EP) | Mixing, Mastering |
2018 | The Dunwich Damnation (EP) | Mixing, Mastering |
2020 | The Sleeping Dread (Single) | Mixing, Mastering |
2020 | The Cthulhian Pulse: Call from the Dead City | Mastering, Mixing |
2021 | Bitter Loss (Single) | Producer |
2016 | My Way (EP) | Engineering, Mixing (tracks 1, 4), Mastering (tracks 1, 4) |
2016 | The Devil Strikes Again / Second to None (Split) | Engineering |
2016 | The Devil Strikes Again | Engineering, Mixing, Mastering |
2017 | Seasons of the Black | Mixing, Mastering |
2014 | Ov Hands and Bestial Pleasure | Mastering |
2014 | Rottendam | Mastering |
2011 | Storm of Vengeance | Mastering, Mixing |
2013 | Blast into Oblivion | Mixing, Mastering |
2015 | Sermon of Ungodly Dreams (Split) | Mastering (track 4) |
2015 | Reckless Manslaughter / Witchtower (Split) | Mastering (track 1) |
2019 | Evil Realm (EP) | Mastering |
2018 | Solitary Men | Mixing, Mastering |
2013 | Perpetual Immaturity Redux (EP) | Mastering |
2012 | Deathevokation | Mastering |
2013 | Manifested Darkness | Mixing, Mastering |
2014 | Death Kult Legions | Mixing, Mastering |
2016 | Emissary of All Plagues | Mixing, Mastering |
2019 | The Hour of the Avenger | Mixing, Mastering |
(show all) |
2004 | Bolted to the Cross | Mastering, Mixing, Producer |
2005 | Congregating the Sick | Mastering |
2006 | Vicar Mortis (EP) | Mixing, Mastering |
2006 | Rotten Rhythms and Rancid Rants (A Collection of Undead Spew) (Compilation) | Mastering |
2007 | Untitled / Dead As **** (Split) | Mastering |
2012 | Kult of the Pneumatic Killrod (And a Collection of Ribs) (Compilation) | Mastering (disc 1, tracks 16-21), (disc 2, track 1-17), Mixing (disc 1, tracks 16-21), (disc 2, tracks 1-8) |
2018 | Neoteric Commencements (EP) | Mastering |
2020 | Invicta (EP) | Mastering |
2014 | Supremacy Undone | Mixing, Mastering |
2016 | Malevolence | Mixing, Mastering |
2014 | Demo (Demo) | Mastering |
2016 | Rotten Tunes | Mastering |
2005 | Ruin the World (Demo) | Mixing, Mastering |
2007 | Demo 2007 (Demo) | Mixing |
2010 | Surmantuoja | Mixing, Mastering |
2013 | Todellisuuden mestari | Mixing, Mastering |
1994 | S.G.R. (EP) | Producer |
1994 | Finis Malorum (EP) | Producer, Mixing, Engineering |
1996 | Far Away from the Sun | Engineering, Remastering |
2020 | Far Away from the Sun | Mastered for vinyl |
2014 | 滅絶 (EP) | Mastering |
1995 | Demo I (Demo) | Producer, Mixing |
2001 | The Early Years: Dawn of Darkness (Compilation) | Recording |
2014 | In Constant Suffering | Mastering |
2015 | Heart of Emptiness (Single) | Mastering |
2006 | Легенды большого города | Mastering |
2010 | Ne, joista ei puhuta | Mixing, Mastering |
2011 | Musta, kylmä, syvä ja samea | Mixing, Mastering |
2009 | Forsaken Symphony | Remastering |
2018 | Letters from the Edge | Mastering |
2019 | The 7 Endless | Mastering |
2017 | Seminal Embalmment | Engineering |
2014 | Beyond the Curse of Death (EP) | Mastering |
2016 | Ungodly Forms | Mastering |
2018 | The Crypts Below (EP) | Mastering |
2019 | Call of Ancient Gods (Single) | Mixing, Mastering |
2019 | Loss of Existence (Single) | Mixing, Mastering |
2019 | Cemetery Slaughter (Single) | Mixing, Mastering |
2019 | Morbid Realms | Mixing, Mastering |
2021 | Till Death Do Us Rot (Single) | Mastering |
2022 | Rites of Gore | Mastering |
2016 | Trinity | Mastering |
2006 | Hellbound Heart | Mixing, Mastering |
2014 | Rebirth Through Brimstone (EP) | Mixing |
2016 | Harrowing Faith | Mixing, Mastering |
2018 | We of Scorn | Mixing, Mastering |
2020 | The Forbidden Arts | Mixing, Mastering |
2021 | Thrill of Fantasy (Single) | Mastering |
2021 | Under the Weeping Sky (Single) | Mastering |
2021 | Abyssum Abyssus Invocat | Mastering |
2012 | Carnival of No Tomorrow | Producer, Mixing |
2014 | Purgatory Princess | Mixing, Producer |
2018 | Planetary Genocide (Single) | Mixing, Mastering |
2018 | Devouring Mortality | Mixing, Mastering |
2020 | The Entombment of Chaos | Mastering, Mixing |
2021 | Resurrected in Chaos (Single) | Mastering |
2021 | Aeons Untold | Mastering |
2018 | The Shadowed Road | Mastering |
2019 | La senda de la muerte (Split) | Mastering |
2010 | Forever More (EP) | Mastering |
2014 | A Price to Pay | Mastering |
2012 | Carpe Mortem | Mixing, Mastering |
2007 | My Dividing Line | Mastering |
2014 | The Suffocating Darkness | Mixing, Mastering |
2015 | Imperial Anthems No. 17 (Split) | Mixing, Mastering |
2016 | The Throne of Armageddon | Mastering |
2015 | Welcome My Sun | Producer, Mixing, Mastering |
2018 | The Deep | Mixing, Mastering |
2011 | Total Depravity | Mixing, Mastering |
2016 | Klañv | Mastering |
1998 | Heavy Metal Machine (Single) | Engineering |
2015 | II: Thin White Paint | Mastering |
2020 | Equinox Ritual | Ritual Inversion (Single) | Mastering |
2010 | Sweet Mississippi Deal | Engineering |
2015 | Pray.Crawl.Suffer | Mixing, Mastering, Producer |
2015 | The Great Bazaar | Mixing, Mastering |
2013 | Leech on Your Brainstem | Mastering |
2013 | CU3E | Mastering |
2015 | Reveries... | Mastering |
2018 | Dark Stars and Eternity | Mastering, Producer, Mixing |
2015 | Volume One: Morpras (EP) | Mastering, Mixing |
2012 | Hordes of Zombies | Mixing, Mastering |
2009 | Justified Genocide | Mixing, Mastering |
2013 | Angelic Encounters | Remastering |
2014 | Global Purification | Mixing, Mastering |
2020 | Violent Death Rituals | Mixing, Mastering |
2019 | Better Dead than Friends | Mastering |
2009 | Daylight Deception | Mixing, Mastering |
2011 | The Binding Cycle | Mixing, Mastering |
2012 | Second World | Mixing, Mastering |
2010 | The System of Nature | Mastering |
2020 | Ascent (EP) | Mastering |
2020 | Descent (EP) | Mastering |
2020 | Horizon's Fall (Compilation) | Mastering |
2012 | The Facts and Terrifying Testament of Mason Hamilton: Tsathoggua Tales | Mixing, Mastering |
2017 | Play Dead | Mixing |
2000 | Cybersonic Superchrist | Producer, Mixing (as "Mr. Dan Swanö") |
2005 | Deadmarch: Initiation of Blasphemy | Remastering (2008) |
2005 | Armageddon March Eternal (Symphonies of Slit Wrists) | Mixing, Mastering |
2007 | In Hora Mortis Nostræ | Mixing, Mastering |
2009 | The Lustrate Process | Mixing, Mastering |
2011 | Bleeding the New Apocalypse (Cum Victriciis in Manibus Armis) | Mastering, Mixing |
2014 | There Is No Earth I Will Leave Unscorched | Mixing, Mastering |
2017 | Of Chaos and Carnal Pleasures | Mixing, Mastering |
2018 | Death Ritual Covenant | Mixing |
2020 | Purgatory | Producer, Mixing |
2021 | Spewing Venom into the Eyes of Deities | Mixing & Mastering |
2009 | Death Devastation Decay | Mastering |
2008 | Vs. Life | Mastering |
1995 | Theatre of Tragedy | Engineering, Mixing |
1996 | Der Tanz der Schatten (Single) | Producer, Engineering, Mixing (track 3) |
2020 | A Rose for the Dead (EP) | Remastering |
2015 | Weird Tales (EP) | Mixing, Mastering |
2014 | 1871 (EP) | Mastering, Mixing |
2014 | At the Feast of Seven Funerals | Mixing, Mastering |
2011 | War into the World (EP) | Mastering |
2012 | When Ice Crowns the Earth | Mastering |
2012 | Niðr ok Norðr (Single) | Mastering |
2013 | Níðing / Waelcyrge (Split) | Mastering |
2018 | De roep van het woud | Mastering |
2004 | Disexist (Demo) | Producer, Mixing, Mastering |
2005 | My Year Zero (Demo) | Producer, Mixing, Mastering |
2008 | Today a Whisper, Tomorrow a Storm | Mixing |
2017 | Thron | Engineering |
2021 | A Dying Wish | Producer |
2009 | Ignored by Fear | Mastering |
2010 | Desire, Freedom and Confusion | Mastering |
2015 | Below the Green | Mastering |
(show all) |
2018 | Sorrowful and Immaculate Heart (EP) | Producer, Mixing, Mastering |
2009 | Total Terror | Recording, Mixing (track 1-20), Remastering (track 21-27) |
2010 | Buried to Rise: 1990-1991 Discography (Compilation) | Remixing, Remastering (Disc 1) |
2020 | Where Paths Divide | Mixing, Mastering |
2012 | Poisoned Nations Holocaust | Mastering |
1991 | The Morbid Act of a Sadistic Rape Incision (EP) | Recording, Layout |
2012 | Ex Inferis (EP) | Mastering, Mixing |
1996 | Crucidiction | Engineering, Mixing |
2021 | The Cosmic Pendulum of Time (EP) | Mixing, Mastering |
1995 | Ancient God of Evil | Engineering |
2020 | Faith in Chaos | Mastering |
1992 | Nyktalgia (Demo) | Mixing, Producer |
1993 | Uncanny / Ancient Rites (Split) | Producer |
1994 | Splenium for Nyktophobia | Engineering |
1996 | As Darkness Falls | Recording, Producer, Engineering, Mixing |
2017 | A New Beginning | Mixing, Mastering |
2014 | U.G.F. | Engineering |
1993 | Ever Since | Engineering, Lyrics (tracks 1, 2, 4, 6 - 10) |
1995 | Emotional Wasteland | Engineering, Lyrics (tracks 1 - 5, 9) |
2017 | A Collection of Worlds - Resurrection | Engineering |
2011 | Kahleiden kantaja (Single) | Mastering |
2014 | Kadotetut | Mastering |
2016 | Verenvalaja | Mastering |
2017 | Anthropogenic Deterioration | Mixing, Mastering |
2011 | Feed the Extermination | Mastering, Mixing |
2013 | The Meaning of Isolation | Mastering |
2010 | Tales of Loss and New Found Serenity | Mastering, Mixing |
2016 | Realms of the Untold | Mixing, Mastering |
1996 | Welcome My Last Chapter | Engineering, Mixing |
2012 | Isländskasagor | Mastering |
2009 | Only Death Awaits | Mastering |
2016 | Childhood of Evil | Mastering |
2020 | Chapter Two | Mastering |
2021 | Chapter Two & a Half (EP) | Mastering |
2015 | Humanity Is a Disease (EP) | Engineering |
2012 | The Black Season | Mastering, Mixing |
2019 | Irminsul (EP) | Mastered |
2013 | Neantification | Mastering |
2018 | This Was Supposed to Be Fun | Mastering |
2019 | Veil of Imagination | Mixing |
2013 | To Our Glorious Dead | Mastering |
2007 | Prominence and Demise | Engineering |
2017 | Horrid Dominion | Mixing, Mastering |
2020 | October Dark | Mastering |
2013 | The Inheritance | Mastering, Songwriting (tracks 1 - 9), Mixing |
2014 | The New Tomorrow (EP) | Mastering, Recording, Mixing |
2016 | The Northern Sanctuary | Mastering, Mixing |
2018 | The Forestroamer | Mastering |
2001 | Moonlight (EP) | Mixing (track 4), Recording (track 4) |
2013 | Internal Caustic Torments | Remastering |
2020 | World Battering | Mastering |
2016 | The Ghost Road | Mastering |
2018 | Slumberjack (EP) | Mastering |
(show all) |
(show all) |
(show all) |
(show all) |
2010 | The Abyss (Single) | Producer, Mixing, Mastering, Engineering |
2010 | Blood of the Nations | Producer, Mixing, Mastering, Engineering |
2012 | Stalingrad: Brothers in Death | Mixing, Producer, Mastering, Engineering |
2014 | Blind Rage | Mastering, Producer, Mixing |
2017 | Restless and Live (Blind Rage - Live in Europe 2015) (Live album) | Mixing |
2017 | The Rise of Chaos (Single) | Producer, Mixing, Mastering |
2017 | The Rise of Chaos | Producer, Recording, Mixing, Mastering |
2018 | Symphonic Terror - Live at Wacken 2017 (Live album) | Mixing, Mastering |
2021 | Too Mean to Die | Producer, Mixing |
1997 | Tumuli Shroomaroom | Producer |
2013 | Under the Influence (EP) | Engineering, Mixing, Mastering, Producer |
2013 | Deceiver of the Gods | Engineering, Mixing, Mastering, Producer |
2016 | Live at La Laiterie (Video) | Mixing |
2016 | Jomsviking | Recording, Mixing, Producer |
2016 | Jomsviking | Mixing (DVD) |
2018 | The Pursuit of Vikings: 25 Years in the Eye of the Storm (Video) | Interviewee (DVD1) |
2007 | Metal | Engineering |
2001 | Wages of Sin | Mastering, Mixing |
2002 | Burning Angel (EP) | Mixing (tracks 1-2 & 4), Mastering (tracks 1-2 & 4) |
2003 | Anthems of Rebellion | Producer, Engineering, Mixing, Mastering |
2004 | Dead Eyes See No Future (Japanese Tour EP 2004) (EP) | Producer, Engineer, Recorded live tracks & Mixed |
2005 | Doomsday Machine | Mastering, Mixing |
2006 | Live Apocalypse (Video) | Mixing |
2008 | Tyrants of the Rising Sun: Live in Japan (Live album) | Mastering, Mixing |
2009 | The Root of All Evil | Mixing, Mastering |
2011 | Khaos Legions | Mixing, Mastering |
2017 | As the Stages Burn! (Live album) | Mixing, Mastering |
2005 | Shadows Are Security | Mixing, Mastering |
2006 | The Darkest Nights (Single) | Remixing |
2006 | A Long March: The First Recordings (Compilation) | Mixing |
2007 | An Ocean Between Us | Guitar re-amping |
1998 | Grind person | Producer |
2001 | Organised Chaos | Producer |
2005 | The Empires of the Worlds | Co-Producer, Mixing, Mastering |
2000 | Silicon Messiah | Engineering, Mixing, Producer |
2002 | Tenth Dimension | Producer, Engineering, Mixing, Photography |
2004 | Blood & Belief | Mastering, Engineering, Photography, Mixing, Producer |
2007 | Alive in Poland (Video) | Producer |
1994 | Extracting the Knowledge (Demo) | Recording, Mixing |
1994 | Death Twitch (Demo) | Producer |
2004 | The Opposite from Within | Mixing, Mastering |
2006 | The Undying Darkness | Mixing, Mastering |
2013 | Captive Bolt Pistol (Single) | Mixing, Mastering |
2013 | Surgical Steel | Mastering, Mixing |
2013 | Zochrot (Single) | Mixing, Mastering |
2014 | Surgical Remission / Surplus Steel (EP) | Mixing, Mastering |
1998 | Caravan Beyond Redemption | Producer |
2007 | Resurrection | Engineering, Mixing |
1998 | Breakfast at Pappa's (EP) | Engineering, Mixing |
1999 | Hit for Six | Producer, Recording, Engineering, Mixing |
2002 | Pistols at Dawn | Producer, Engineering, Mixing |
2006 | Thornography | Mixing, Mastering |
2008 | Honey and Sulphur (Single) | Producer, Mixing, Mastering, Engineering |
2008 | Godspeed on the Devil's Thunder (The Life and Crimes of Gilles de Rais) | Mastering, Producer, Engineering, Mixing |
2010 | Darkly, Darkly, Venus Aversa | Engineering |
2007 | The Hinderers | Recording (additional) |
1996 | Temptation / Between Night And Day (Single) | Engineering |
1996 | Temptation | Engineering |
2007 | The Ills of Modern Man | Mixing, Mastering |
2016 | Beast | Mixing, Mastering |
2007 | The Last Kind Words | Mixing, Mastering |
2009 | Pray for Villains | Producer (additional guitars), Mixing |
2011 | Dead to Rights (Single) | Mixing |
2011 | Beast | Mixing, Mastering |
2007 | Incinerate | Mastering (Disc 2, tracks 1 & 6), Mixing (Disc 2, tracks 1 & 6) |
2007 | Incinerate | Mastering, Mixing |
2010 | Gateways (Single) | Mixing, Mastering |
2010 | Abrahadabra | Mixing, Mastering |
2021 | A View from the Top of the World | Mastering, Mixing |
1994 | Bow to None | Mixing assistant |
1995 | All the World's a Rage | Producer, Mixing |
2004 | Tempo of the Damned | Producer, Mixing, Engineering, Mastering |
2005 | Shovel Headed Kill Machine | Mixing, Mastering |
2007 | The Atrocity Exhibition: Exhibit A | Producer, Engineering, Mixing |
2008 | Let There Be Blood | Mixing, Mastering |
2010 | Exhibit B: The Human Condition | Producer, Engineering, Mixing, Mastering |
2014 | Blood In, Blood Out | Mastering, Engineering (drums), Tracking (drums), Mixing |
2021 | Persona Non Grata | Mixing, Mastering |
(show all) |
1999 | Faceless | Mixing, Producer, Engineering |
2006 | Eradication (Demo) | Engineering |
2015 | Genexus | Mixing, Mastering |
2021 | Aggression Continuum | Mixing, Mastering |
2000 | Fozzy | Mastering, Mixing |
2002 | Happenstance | Mixing, Mastering |
1994 | Godsend (EP) | Producer |
1997 | The Slaughter of Innocence, a Requiem for the Mighty | Engineering, Producer, Mixing |
2011 | Save Us from Those Who Would Save Us / On Earth as It Is in Hell (Single) | Engineering, Producer, Mixing |
2011 | Human Remains | Mixing, Producer, Engineering |
2013 | Curse & Chapter | Engineering, Mixing, Producer |
2010 | Damnation's Wings | Engineer, Mastering, Mixing, Producer |
2015 | Hell House | Mastering |
2006 | The Scattering of Ashes | Mixing, Mastering |
1997 | Iron Monkey | Mixing, Producer, Recording |
1998 | Our Problem | Mixing, Producer, Engineering |
1999 | We've Learned Nothing (EP) | Producer, Engineering, Mixing (as "Andy "The Rock And Roll Doctor" Sneap") |
1999 | We've Learned Nothing / Church of Misery (Split) | Engineering, Mixing, Producer |
2007 | Genesis | Mixing, Mastering |
2020 | Terminal Velocity | Mastering, Mixing |
2018 | Firepower / Breaking the Law (Single) | Producer (Side A) |
2018 | Firepower | Producer, Engineering, Mixing, Mastering |
2009 | Cybion | Engineering (guitars) |
2015 | Of Ghosts and Gods | Mixing, Mastering |
1996 | Kill II This (Demo) | Producer, Mixing |
1998 | Deviate | Mastering, Digital Editing, Mixing |
2000 | Trinity | Producer, Mixing, Mastering |
2002 | Roadrunner Roadrage 2002 (Split) | Mixing (tracks 1 & 2) |
2002 | Alive or Just Breathing | Mixing, Mastering |
2004 | The End of Heartache | Mixing, Mastering |
2013 | Disarm the Descent | Mixing, Mastering |
2001 | Violent Revolution | Producer, Engineering, Mixing, Mastering |
2003 | Live Kreation (Live album) | Engineering, Mixing |
2003 | Live Kreation - Revisioned Glory (Video) | Engineering, Mixing |
2005 | Enemy of God | Producer, Engineering, Mixing |
2008 | At the Pulse of Kapitulation - Live in East Berlin 1990 (Video) | Remixing |
2020 | 666 - World Divided / Checkmate (Split) | Producer |
1987 | It's a Lot Less Bover than a Hover (Demo) | Producer |
1988 | Mowdeer (Demo) | Producer |
2002 | Conceived in Fire | Mixing, Mastering |
2010 | The Infinite Order | Mixing |
1999 | Pleasures Pave Sewers | Producer, Engineering |
2011 | Necropolis Transparent | Mixing, Mastering |
1997 | The More Things Change... | Mixing, Engineering |
2000 | Year of the Dragon: Tour Diary Japan (Compilation) | Mixing (tracks 2, 4, 5) |
2002 | Enlighten Me (EP) | Producer (1-5), Engineering (1-5), Mixing (4) |
2003 | Masterplan | Producer, Recording |
2004 | Back for My Life (EP) | Producer, Engineering |
2005 | Aeronautics | Producer, Engineering |
2007 | United Abominations | Producer, Mixing, Engineering, Mastering, Recording |
2009 | Endgame | Producer, Engineering, Mixing, Mastering |
2011 | Th1rt3en | Engineering |
(show all) |
1997 | Perfect Life? | Producer, Mixing |
1998 | Ten Miles High | Arrangements, Producer |
2020 | Pach krvi (EP) | Producer, Engineering |
1997 | Inside the Torn Apart | Mixing |
1997 | Breed to Breathe (Split) | Mixing |
2000 | Dead Heart in a Dead World | Producer, Engineering, Mixing, Mastering |
2005 | Enemies of Reality | Remixing, Remastering |
2005 | This Godless Endeavor | Producer, Engineering, Mixing, Mastering |
2008 | The Year of the Voyager (Live album) | Mixing |
2010 | The Obsidian Conspiracy | Mixing, Mastering |
2011 | Enemies of Reality | Remixing, Remastering |
1998 | Dead (Live album) | Mixing |
2007 | Killing Peace | Producer, Mixing |
2009 | Live Damnation (Live album) | Mixing |
2002 | Deliverance | Mixing |
2003 | Lamentations - Live at Shepherd's Bush Empire (Video) | Recording, Mixing |
2006 | Lamentations - Live at Shepherd's Bush Empire (Live album) | Recording, Mixing |
2016 | Mean, Green, Killing Machine (Single) | Mixing |
2017 | The Grinding Wheel | Mixing, Mastering |
2019 | The Wings of War | Mixing, Mastering (track 11) |
2007 | What Doesn't Kill Us | Mixing |
1998 | Pissing Razors | Engineering, Producer |
1999 | Cast Down the Plague | Producer, Engineering, Mastering |
2015 | Time Waits for No Man (Compilation) | Executive producer |
2011 | Stay Down (Single) | Mastering |
2011 | Revenge for the Ruthless | Mastering |
2004 | Rise to Addiction (EP) | Producer |
2007 | A New Shade of Black for the Soul | Producer, Recording, Mixing |
2007 | Dreamweaver | Remastering |
2007 | History of a Time to Come | Remastering |
2013 | Sacrifice | Producer |
2013 | Unplugged and Strung Up (Compilation) | Mastering, Remixing (tracks 1-4), Mixing (tracks 6, 8) |
2014 | St. George's Day Sacrifice - Live in Manchester (Live album) | Mixing, Mastering |
2015 | Battering Ram | Mastering, Engineering, Mixing, Producer |
2016 | Let Me Feel Your Power (Live album) | Mixing |
2018 | Thunderbolt | Producer, Engineering, Mixing |
2019 | Thunderbolt: The Singles (Boxed set) | Mixing, Engineering |
2021 | Inspirations | Technical adviser |
2022 | Carpe Diem | Producer, Recording (guitars) |
1995 | Walking Knife (EP) | Producer |
1997 | Bound, Gagged and Blindfolded | Mixing, Producer, Engineering |
1999 | Disembody: The New Flesh | Producer, Mixing |
2002 | Revolting Room | Additional tracking, Mixing |
2002 | On Fire | Mixing (tracks 2, 3, 6) |
2005 | Live Fire! (Video) | Mixing |
2002 | Under the Cross | Mixing |
2003 | A New Darkness upon Us | Producer, Engineering, Mixing, Mastering |
2009 | Sovereign | Mastering |
1999 | The Gathering | Mixing, Engineering (additional), Mastering |
2001 | First Strike Still Deadly | Mixing |
2008 | The Formation of Damnation | Recording, Engineering, Mixing |
2012 | Dark Roots of Earth | Recording, Engineering, Producer, Mixing, Mastering |
2016 | Brotherhood of the Snake | Mixing, Mastering |
2018 | The Gathering | Remastering |
2020 | Titans of Creation | Mixing, Mastering |
(show all) |
2003 | Don't Look Now...I'm Living (EP) | Producer, Mixing, Mastering |
2004 | The Wolves Are Hungry | Mixing, Mastering |
2008 | The Unholy Feast | Mixing, Mastering, Tracking |
2014 | The Hybrid | Mixing, Mastering, Producer |
2005 | Ascendancy | Mixing, Mastering |
2008 | The March | Mixing, Mastering |
2017 | Revelation | Mastering |
2019 | Bury the Pain | Recording (drums), Producer, Mixing |
You may have a point.The music studios I've worked in were standardized. But they were producing music for both TV and CD. I would imagine that by the time the recording reaches the mastering stage, it would have to be calibrated.
What calibration are studios using if they aren’t standardized?
Yes, with some genres it's not uncommon to "wear many hats" or even all the hats in some cases (even more so with EDM than with metal for example), although generally the recording engineer is a separate role from the Producer and with some genres, this is virtually always the case (classical music for example). Wearing more hats is a long term trend to some degree, for example the role of mix engineer is very rare these days (in any genre), it tends to be done by the recording engineer or Producer, and the role of "Tape Op" effectively doesn't exist any more. However, what I wrote is still valid because ...They maybe do because on the projects listed below they wear many hats? Note how Andy Sneap basically does everything at times!
Yes but they "bring their own sound to the table" as Producers, etc., not solely as recording engineers. Note that it's very rare to be both the Producer and the Mastering Engineer of the same tracks, with any genre. One of the main points of using a mastering engineer is the employment of a fresh/objective, highly trained and experienced "set of ears". That important point is going to be lost if the Mastering Engineer is the same person as the Producer.Also take note these two were actually the two main ones I was thinking about (when I made that post) beforehand. I didn't specifically look for people that were multitalented, I mean these are some of the best in the world right now, as far as Metal goes. There are more I could list, but (to me) those few have less of an original sound? And it's not expectation bias.............. as their recordings were noted to be special before I knew they were involved. These two are highly respected and bring their own sound to the table.
The metal world is somewhat different, it's a rather specialised world with specific processing and production techniques that defines it as "metal". However, it's quite common for engineers "to get their start as musicians", I did for example and some music engineering schools require students to have proficiency on a musical instrument in order to apply.I'm not alone in my appreciation of them. I'm also not alone in feeling they both have their very own sound. Maybe the Metal world is different in that all the people I'm referring to are actual musicians and got their start as musicians?
All decent recording engineers know and understand the "recording element they are in" and those who wear fewer hats tend to know and understand better than those who wear many hats.Also they seem to know and understand the recording element they are in? At least the results offer unique proof of that?
Very interesting discussion
I honestly wish I could tell the difference any more.
But, once you hit your 60's, and/or catch something like Meniere's disease, you just can't tell.
So.
Similar to other aspects of life, good quality audio is for the young.
Who are ironically less able to afford it, than old farts like me. Who can't hear it.
I suppose the moral of my story is, enjoy your music while you can. ...
No, the only places that use the x-curve are film dubbing theatres/stages. Film dubbing theatres are very large compared to music studio control rooms, have full theatrical sound systems and don’t have live rooms for recording music. Here’s a famous example:I think the studios I've worked in are all calibrated to the "x curve" then. Studios here in Los Angeles do both music and TV/movies. I've never heard a head engineer mention anything but the standard calibration.
