I agree 100% with you all! Audiophile grade headphones should always be able to produce sub-bass. But I guess the typical consensus, is that open backed headphones are uncapable, but I think thats crap. They might not be able to hit sub-bass as hard as closed back, but if they are finely tuned, they should produce.
Maybe with the planars. With dynamic drivers I still have my doubts.
That's not true.
Look at planars in that regard.
Many of them are capable to produce sub bass down to 20Hz without getting rolled off.
But to reach these lows they need a lot of power.
There are several Audeze and HiFiMan planar magnetics on the graph tool that I posted above, if you want to check out their frequency response...
https://crinacle.com/graphs/headphones/graphtool/
The open-back planars are well-extended in the bass. But most have little or no elevation to speak of in that range. They are either flat in the bass and midrange (HiFiMan). Or have a slight downward slope toward the bass (Audeze), rather than a rise. That seems to be fairly typical for open-back planars. The Closed Audeze LCD-2C has a slight shelf in the bass.
Since these already have some bass in the lower frequency range, it might be possible to adjust the frequency response with an EQ, or with the tone controls on a receiver, or mixer, or using a dedicated tone-controlled, like the Schiit Loki (if you have no EQ features on your amp or computer) to improve their bass response a little, as bagwell359 suggested above. It's something I've never tried though. And I have not had great luck with it on dynamic open-back headphones.
Other than closing the headphones up, there might be one other potential way of adding some bass and sub-bass to an open-back headphone which does not currently have much low-frequency response. If you have an amp with preouts on it, you could try connecting those to a sub-woofer under your desk or next to your chair, or wherever you usually listen to your headphones.
I have not tried this either, so not entirely sure it'd work. You might, for example, need a pretty fast sub-woofer, because there could be a slight delay between the sound in your headphone, and the bass. Some experimentation would probably also be necessary to figure out the right volume and frequency range for the sub-woofer, to match the response of your headphones, and acheive the best cross-over between the two transducers.
This would obviously not work as well for portable applications.
