kraken2109
- Nov 28, 2013
Maybe the tracks weren't level matched?
I think only the quality of the sound source+headphones are the key to experience the possible audible difference between the two formats.
The fact you say only Apple products will play ALAC is not true. All of the Hi-Res Players out now will play ALL formats. My iBasso and FiiO both play all formats (ALAC included). The Astell & Kern , Hifiman and PONY will also play all formats.
"This isn't true" This is where we disagree. I have better things to do than spend my day to prove myself how right I'm.
Confirmation bias. Placebo effect. Look them up.
If you notice audible differences from different lossless format and you are sure they are bit identical, then you need a better, properly implemented DAC. Been there done that.
wouldn't the dac receive the same basic PCM format in any case? I would imagine a difference (if it exists) coming from badly done conversion when creating one of the files, or the player software/computer to create a particular problem when extracting one of the files. or our usual best seller, people mistaking 2 masters for the same song.
but I don't see why the DAC would play any role in this?
Jitter differences. Some very expensive "audiophile" DAC can't handle them, while any cheap mass market DAC will.
