- Apr 9, 2011
Im asking on the appreciation thread but here will work too. I nee a cheap approx $100 desktop amp to drive the Q701s. My E17 has just enough. O2 or E9 or something else?
I can't find the correct measurements (there are at least 3 articles on the O2 on that blog, they are wildly confusing, and could use a general article with quick info like output voltage), but I'm amost sure the O2 has more power than the E9 and can drive the K/Q701 to painful levels on low gain.
Yeah the website is also where my problem comes in and I have other stuff to do right now.
I know you can have more power on the O2 if done right but it's just the idea of it you know. Portable O2 and E9..... however in the back of my head with no info on those two I still believe E9 is more powerful...not that it matters. A review on the E9 said that driving HD600 series Sennheisers got to very loud on 1/3...less of the volume knob..that's...a whole lot of power.
Somehow I think you're confusing an amps output power with it's ability to produce the most accurate, and and true to the source, sound. There's no doubt that the O2 has more than sufficient power for the 70X....plus if you go by reviews, it will provide the most 'flat'/accurate sound you can get for an amp in that price range....and a lot higher. If you want to spend a bit less, go for the E9. 'Power' is a non issue with either of those amps and the 70X.
i personally enjoy my K701 with my WA6-SE
i definitely find grado more enjoyable at first though.
I can try.Remember, this is my opinion.
Personally, I do like the RS2i's more, but they are probably my favorite headphone out of everything that I've heard. Very well balanced, and they don't do a lot of things wrong. Keep in mind that I think most Grados with bowls are too bright, so I use comfies with them.
Grado has the "soundstage in your head" effect, which I don't mind at all. The Q701's are probably more of a typical headphone soundstage where there is some distance between you and the music. (More like speakers, IOW, but also more detached too IMO.)
The RS2i's do have more of a low end. Maybe not as deep, but more apparent mid-bass. I just got my 2nd pair of Q701's, and I am still struggling with whether I think they have enough low end or not. But that's me. (Still doing some initial burning in too.)
So in the end I think the Grado's are more immediately likeable, but check back with me in a few weeks about the Q701's to see if my opinion changes or not.
