I have the N90Q for about a week (firmware B1.01).
Positive impressions
-The sound is extremely precise (fast), clean, and clear.
-The soundstage is wide and deep (in Studio or Surround mode).
-The frequency response is near to the perfection (especially after the TrueNote Calibration).
-The volume adjustment on the right ring is very practical.
Negative impressions
-For my head, I find the AKG K712 (open-back) more comfortable. The N90Q (closed-back) exerts a higher pressure around the ears. And, after a few hours, it exerts an unpleasant pressure on the top of the head.
-The overall build quality is good, but the size adjustment is too easy to adjust. So it’s necessary to adjust the size each time the headphone is manipulated. And on my unit, the left swivel produces some small mechanical squeaks when I move my head.
-And for me the worst point (maybe a defective unit ?) : it produces a permanent very small white noise when it’s power on due to the always on ANC (Active Noise Cancellation). This noise is generally covered by the music (or street noise, if you use it in the street), but during the pianissimo passages or silences, I can clearly hear this noise. It’s probably not important if you use this headphone in the street (or car, plane), but in a silent room this noise bothers me. It’s a shame that AKG doesn’t allow to disable/enable the ANC. This situation is a little absurd : in my very silent room, my open-back K712 (with my DAC and amp) produces less (no) noise than my N90Q which is a closed-back with ANC.
General notes
-Generally, I use the Studio (or sometimes Standard) mode to play music, and the Surround mode to watch movies.
-By default, when the N90Q is plugged for the first time on Mac OS X, the sampling frequency and quantification are set to 48kHz/16bits. But they can be set to 96kHz/24bits (in the Audio/MIDI panel).
-I use it only with the USB input, because it’s a no-sense (in term of quality) to use it with the mini-jack input (internal DAC can’t be bypassed ---> previous posts).
