LifeAspect
sennheiser already has an answer for the k812, it's called the HD800 and it was released in 2009.
At the moment there is no answer for the AKG K812 Pro not from Sennheiser, Beyerdynamic or the other manufactors. Its a very high analytical headphone with more resolution than the other models (i haven´t heard the SR-009). But not every like this extrem analytical sound!
Not really. I consider the Sennheiser HD800 as part of the old generation headphones that require high end amplifiers. It's not the answer for the AKG K812.
The next generation headphones are more efficient and can sound great from even your iDevice or laptop. If Sennheiser can make a HD800 that is easy to drive, then they have the answer for the AKG K812.
edit: The AKG K812 is still overpriced though if the HD800 is priced at only 1200 euro while sounding better apparently.
Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
At the moment there is no answer for the AKG K812 Pro not from Sennheiser, Beyerdynamic or the other manufactors. Its a very high analytical headphone with more resolution than the other models (i haven´t heard the SR-009 ). But not every like this extrem analytical sound!
The HD800 it's considered by many to be analytical as well, but because of this some people find it to lack euphony and sound sterile. Could the same be said of the K812?
I don't like this idea of "new generation of headphones" one bit.
..."Next-gen" headphones?...
OK.
:rolleyes: :rolleyes: :rolleyes:
I beg to differ? There are numerous user saying the Vali pairs very good with HD800, and it's $120. They go as far as saying they don't feel the need to upgrade to more expensive amps.
And when I auditioned HD800 and K812 both are running from the same amp, which was the WA7 (very bad pairing with K812), and Soloist SL (which is not at all a 'high end' amp).
lol why not? off-topic but hifiman is making a new generation of orthos that weight lighter. more innovations are always good
