lejaz
- Nov 30, 2008
Do you know if you can purchase the 242HD pads, or do they just sell a 'generic' k24X pad? I'd like to try the 242 pads on my 240S since, if I understand you correctly, that would make the 'S' more 'neutral'.
Haha, it's totall the other way around
It's due to the different pads. The pleather of the K240s give them a bit of a bass boost, while the velours tame the bass a bit.
Woops, if you were talking about the K240M (600ohm) I have to agree with you.
Prefer the K240 series in this order.
K240 Sextetts MP (most musical)
K242HD (most neutral)
K240s (boomy but fun because of that)
K240M (quite neutral, with less than neutral bass)
EDIT:
note that the
K242HD
K240s
K240MKII
are exactly the same in terms of dampening, driver, baffle .etc
the difference in sound is due to the different pads with different inner diameter (pleather smaller hole than pleather)
They differ in colour and cable.
