SilverEars
- Sep 18, 2013
I'm reading 'Crinacle is Trash just like Sony and Bose' lolRight. And if you read up thread the immediate response was crinnacle is trash. Just like Bose and Sony.
I think you meant Crinacle thinks it's trash. I'll eventually hear it for myself to see if there is any use case scenarios for a $550 wireless ANC headphone if I already have the XM3 that is sufficient to do it's duties on flights.
Now, I think APP is practical, but don't see the same level of practicality with APM at $550 if I have a home rig that just sounds better. I'll just bust out my XM3 for flights. APP for run and I can use on flights as well and fit in my small pocket and don't have the atrocious bra case to turn it off. Bad idea. With TWS it makes sense, but not with headphones that do not inside a charging case.
Will hear it for myself and we will see once the hype dies down. I think it's at a hype point since it's from Apple.
My XM3 fits easily in the case for stow away as well and light when I wear it. I don't need the weight and the aluminum. And I can power it off with a button provided.
Let's ask this, how does it compare to K371 in terms of SQ?
