Every time it feels like I'm close to making this thing work some problems just keep coming up.
I added a 10R resistor between the rectifiers and the first C and a hammond 2.5H choke between the first and second C to the PS and added the heater gnd reference circuit. The choke cut hum dramatically but The 10R resistor had absolutely no effect on B+ voltage.
I replaced the volume pot with an alps blue 100k and that seems to be working fine. Hum is fairly minimal, if I move the wires from the pot to the inputs on the pcb around a little bit the hum changes from barely audible to unbearable. I have some different grounding ideas yet to try and see if I can eliminate it.
My main concern though is that the headphone output seems to be "clipping" badly. I don't know what other term would be appropriate to describe it. The sound cuts abruptly and I get a very nasty pop with a little pause before it pops again unless I back off the volume. It happens quite a bit earlier on the volume knob with my 48 ohm JVC cans vs. the 300 ohm Sennheisers.
It doesn't seem to happen on the line out, but I'm driving a LM3886 chipamp with fairly high gain so I can't turn it up very far before I start to go deaf anyway.
The other big issue is a very nasty turn off thump. I switched the aikido off a couple of times with headphones on my ears and I thought it ruptured my eardrums, it was actually painful. It does the same thing to the line out on shutoff, the woofers on my speakers must be moving through their full travel at shutoff, and the speaker protection relays in my amp really freak out.
I'm feeling rather frustrated again
Is there a possibility that since I'm using 10M45S for the solid state buffers that I'm running into the 50mA current limit once again on the headphone output? Or is it possible that the 180 ohm cathode resistors are running my tubes too "hot" and they are running out of breath?
