BoilermakerFan
- Jan 2, 2008
The tube buffered gainclone runs a 6922 at 35V and the chip at 24V so I suspect the sound quality suffered at 24V. Joe didn't specifically say he tested it at 24V, but I'm sure he did as he likes to keep the design as simple as possible. They will sound better at 48V though.
One H-PS-1 is enough to run the Aikido 24V board, so it should have the power to run two separate Octal boards and a buffer.
I have the IRF510s and IRF610s to try in my 24V board and plan to run them at 24V with LM317, LT1085, and the 10M45S current sources. However, the bias current resistor changes for the LV regs versus the FET reg.
I will also be testing the IRFZ35 FET from the Millett Hybrid MAX in the Aikido and the IRF510/IRF610 complimentary pairs will be auditioned in the MOSFET-MAX when I build it on the new rev1.2 board.
Originally Posted by nano_machine /img/forum/go_quote.gif Has anyone tried building this with this with 6DJ8/6922's at 24V? 6GM8's are getting so difficult to find. |
Originally Posted by rodentmacbeastie /img/forum/go_quote.gif I am still awating my replacement H-PS-1 board from Tubecad. I am wondering if one of these PS kits is enough to power two boards? I should get another H-PS-1 board right? Any suggestions for a transformer? |
Originally Posted by rodentmacbeastie /img/forum/go_quote.gif Would you be able to feed an IRF610 with a LM317 in the buffer? I have some IRF610 from my D1 I/V stage left over znd wondered if they would sound better? |
