Jun 27, 2024 at 10:26 PM Post #31 of 685
Whats the cpu model how much ram?
How long does it last? How big is the battery?
Jun 29, 2024 at 3:10 AM Post #33 of 685
I am wondering how the sound signature of P1 is like. Is it tending to a warmer side with rich bass?
Jun 30, 2024 at 2:01 AM Post #35 of 685
I am also wondering how the Equalizer of P1 performs. I am a long time user of Sony Walkman ZX series and their EQ I reckon is one of the best in the market. Hope that the EQ of P1 will be on par with the Walkman ZX series.
Jul 4, 2024 at 2:03 AM Post #37 of 685
it launches next month, so by that time you will know, or you can test it out yourself...
I am invited to join a listening session of P1 on this Sat, hosted by a local head-fi dealer, I will test it out by then.
Jul 4, 2024 at 4:37 AM Post #39 of 685
Photo being shared by a local head-fi KOL:
Jul 4, 2024 at 3:18 PM Post #41 of 685
Great pic, curious to hear your thoughts on it. Did you try the EQ and is it still as limited as A&Ks current offerings (especially Q-factor)? Given your flair, I'm also curious on any subjective impressions you have. Hopefully you were able to test it with headphones/iems you know well :)
Jul 4, 2024 at 7:27 PM Post #42 of 685
Yep, I will bring along my well known IEM there to test thoroughly, and see whether the EQ of P1 would work efficiently with my IEM. Hopefully it would result in something positive as I am a heavy EQ user. I use to have presets for different IEMs in my Walkman ZX707. In my memory when testing the AK SR35, its EQ did not have much effect on the sound tuning, I hope P1 would not be the same case as SR35.
Jul 4, 2024 at 8:46 PM Post #44 of 685
The navigation button could be tricky since you can only use one button for Play/Pause, next, back.
I see that you own some Campfire audio iems, which are known for their super sensitivity, would you mind to bring them along for a try? Since the output impedance for the 3.5mm is 1ohm, it should be a good pairing.
Jul 4, 2024 at 10:48 PM Post #45 of 685
I don't have any IEM equipped with 3.5mm plug (all of them are with 4.4mm balanced plug). As you recommend, I will bring the CFA Bonneville for the test. The output impedance for the 4.4mm is 2ohm, almost the same as 3.5mm.
