sennphile
- Feb 4, 2017
Thanks for your response.I am still on fw 2.6.3 and it has both players. Not sure of wav, use flac or dsd entirely
Hi all,
Already got my ARM2... Sounds so great ... !
I'm actually lookin for a combo DAC USB (or combi DAC/amp), with the same sound effect as this ARM2... around 500-600$$ max...
Do you have any idea?
Thanks !
Check the amp forum thread for desktop setups with schiit gear and stuff like that. You will get much better help in thereTo connect to my computer? Not lookin for another DAP but a combi to listen some music with my computer / headphones..
Do you have any references?
Is there a way to disable the side buttons on the M2? Sometimes I'll be listening to it and go grab the DAP which might be sitting beside me and my fingers will inadvertently hit the seemingly oversensitive skip fwd button or something.
Btw...
How is your AR-M2 review coming along, @Hawaiibadboy ?
Not sure how to disable swiping
Not swiping, the hard buttons on the side of the player. Too sensitive.
hi all, i just updated to fw v2.6.3.0 and couldn't create playlist on AR Player PRO. Anyone experiencing the same problem? any suggestion?
I am able to add files to a playlist. No problem for me.
I can create playlist on AR music player, but not on AR music player PRO.. too bad i like the player PRO very much.. hmm i wonder what happens with my unit
