- May 24, 2012
Class A operation often leads to a lot of power being dissipated as heat. I am guessing that the AR-M2 may get rather hot if used in a pocket, during summer temperatures? Is this so, or does it run cool? (I did see the mention of copper heat spreaders to direct the heat away from the PCB and towards the aluminium chassis, but still...)
I think it will find some success with cans lovers.
Well depends what your doing with it running just from Spotify offline yields quite a cool temperature, now on the other hand if you are streaming or using high res the device becomes a few degrees hotter for sure.
On the whole the unit doesn't heat up too much it only gets a little warm unless you're really pushing it screen on, youtube, hard to drive cans etc. I owned a Cowon Z2, nowhere in the same league but, that thing would get hot and to boot the battery life was just well amazingly crap.
I am becoming a little bit of a fan boy here but the player for me is suburb. In my review I briefly mentioned the HD700 If I can get a pair on loan I'll add in some impressions, reason being is when I initially heard the M2 it was the first headphones I got to listen to out of it and man just never heard them sound as good. Put it this way I would take this over a CLAS+Duet set up anyday balanced mode or not.
I'm sure it will find a place amongst can lovers although, an actual 1/4 inch socket or even an adaptor would have been a nice addition seeing as it was created with hard to drive cans in mind.
