SQ wise theres a lot budget earbud that can destroy any budget iem out there. But hey we're on earbud thread so we're bias..KZ ATR the best for the price. Around 5 USD on GearBest's flash sales.
Welcome. Check out the rave on budget vido eaebud.
Yeah, it is. Keep in mind that no mic version has J cable, right side has longer cable that goes behind your neck. Really not a fan of it, but it's 4$ and you can'y really complain.Is this the Vido earbuds people here been raving about?
https://www.aliexpress.com/item/New...ug-Earbud-Bass-HIFI-Earphone/32806045266.html
If it's not. Can someone link me them. My Philips she3800 just died . I was planning to get another pair of Monk+ but I enjoy something warmer and bassier. So I thought I ought to try out this Vido.
Yes they are. Just buy Vido and never look back.
Looking to replace some Samsung stock earbuds that came with a Note 5.
Looking for something that will sound better for less than $15
Have (awesome):
Vido $5
Getting (probably awesome):
DIY MX500 $10
Have (very good, and smaller housings so good for falling asleep with):
Qian39 $5
I would also recommend getting the Monk+ package of thin foams (many including myself prefer them over other foams).
Can't get the alixepress links to work. Says to log in. How to the vidos compare the monks?
So which of these budget earbuds you suggest for symphonic metal and rock music? I'm thinking of TY Hi-Z 32 or 150 ohm versions.
Personally I'd go for the Vido, Monk or Seahf 32 or Seahf 150. The latter two are similar to the TY variants but I much prefer them, as I don't like too much treble or peaks in upper mids. All the above sound good to me, and I'm partial to a bit of power/symphonic metal (Sonata Arctica, Rage, Helloween, Delain) and classic rock.
I haven't done a direct comparison, I just know both are extremely listenable and quite more-ish, I'll have a go later and post backThank you for answering. How would you compare Vido to Seahf:s?
