pinnahertz
- Mar 11, 2016
Headaches and the feeling of being under pressure indicates you're trying too hard. There is no time limit for any comparison except of that you place on it yourself. If you feel there might be more difference by listening longer, then by all means do so!Caveats are that some effects could sink in over a period of time when you're not under pressure, but even if that were true, how would you prove it?
Remember, in an ABX test we are not trying to determine preference. If you are, you've just added an additional amount of pressure to yourself. You're trying to discern a difference, and pair X to either A or B, not try to figure out which is better.Also perhaps your brain 'fills-in' after a while. Usually I seem to think the second one was better, something I've noticed before in myself with small differences. Also the DAC I used tends to smooth things over compared with the one in my CD player even at 44.1.
See, this is exactly what I was trying to warn about: a rapid, forced, high pressure test, then trying to extract something the test is not designed for, worsening the situation.
Blind comparisons in general? No, not true at all, they do show up audible differences that "most or all" people can discriminate. Perhaps not in a sampling rate comparison, but that's actually expected. There are plenty of things that can show very high percentage results, though.I've done some searching on blind tests, and yes, you're right. It seems most to all people can't discriminate on blind comparison and neither can I in the situation I have described. Sorry if I've wasted your time.
If the test was presented by someone selling a product, it wasn't real.There are errors of a few uS in one zero crossing point I looked at between the various files when examined in Audacity. In fact re-sampling entirely removes one small cycle through the zero point I looked at. I haven't looked for patterns in time error, but we're looking at a file created presumably with a wideband LPF.
Leaves me wanting to repeat the analogue vs ADA test and wondering if it was for real!
