SimonPac
- Jun 7, 2015
Well gents, I just couldn't keep quiet. DAC's the same-no. I have Wolfson 24-192, Crystal 24-192 and BB PCM63P-K. set up as 44.1-20. PCM63P -K spec was state of the art laser trimmed R2R, used in many pro projects including digital desks, circa 2000. The K grade is trimmed to better than -96dBm THD which actually corresponds only to 16-bit resolution but executed absolutely perfectly. So ideal for CD. Even most top end commercial players tended to get only the basic grade of this chip; the goodies went to pro gear and people like Linn. They really are very good with the right filter. I have a PMD100 filter, actually phase-linear. I can switch instantly between any two of the DACs with the same CD 44.1 stream as source. The Crystal, a consumer level chipset, is quite 'musical' and 'forgiving', fairly sweet treble, lacks ultimate clarity and punch, fuzzy on bass instruments. Wolfson (it's not their top chip and I suspect the propriety filter used, have been getting round to doing an impulse test to check filter type..)..sounds polished, clean but ultimately a little muddled on CD. BB PCM63P-K with PMD100 filter I actually like best. Seriously, my player with the Crystal consumer DAC sounds a way away from the pro BB one. And that's all at 44.1-16. There's no way ever I'll agree they're the same. it will depend quite a bit on what you play them through, but high end headphones are amazing these days. The BB setup has slam, pace, clarity in complex passages and resolution after the others. IMO of course. Yes, I know they all measure THD-FR-PR-IMD-SNR-pitch- stability better than anything analogue except a very good amp.
Anyway....MAIN POINT
I have decided to try and find time to listen to the same file, analogue master, at 44.1-16 and 192-24, blind. I'll get someone else to randomly play them in order, either HD then CD or vice versa. I'll ask the person to record which was played first. I'll repeat this a few times and check and see how I did. How's that?
