cobaltmute
- Jul 2, 2008
Okay, I was taking some of the link as gospel so I did a quick test in sim:
V1 = 12V AC rms
D1, D2 = 3N254
C1, C2 = 100uF
R3, R4 (load resistors) = 499 Ohms, just because that is what came up when I went to add them to the schematic
R1 = 0.5 Ohms
Oscilloscope test points are the top of the C's. Top trace is R1, Bottom is R2
I played with R2, varying from 5 to 100 Ohms. 100 Ohms is what is pictured chosen for it very evident effect. Putting 100R in line is not what I'm planning on doing for dissipation and voltage drop reasons. Increasing the value of R between the bridge and the capacitor does smooth the waveform in all cases I tested. It seemed that the turn on "spike" occurred over a "longer" duration in time creating a smoother waveform.
I also tried adding bypass caps to the bridge in the sim, which didn't appear to do anything.
Feel free to sim and rip apart anything I just said. I know well enough that sims and my methodology can be wrong
V1 = 12V AC rms
D1, D2 = 3N254
C1, C2 = 100uF
R1 = 0.5 Ohms
