rds
- May 4, 2008
@rds: Given our proximity, I'll send you a proto (or two) to test.
sounds good
I'll take one too. Sounds like the perfect PS for a budget/compact M^3.
Colbaltmute, do you have any specifications as far as input voltage/output voltage, max difference between the two, etc.?
I have a transformer that outputs 38VAC when not loaded (not sure if that matters)
And I think the powers supply needs to support 0.5 amps for M^3
Assuming I need to drop 7V's to maintain regulation, thats 7*.5 = 3.5 watts...
The issue that I see here is that 38VAC through a full wave bridge = ~53V rectified.
This is where I am a bit confused. I have read that the diode bridge will bring the voltage up.
However, the transformer is currently hooked up to a power supply circuit.
The voltage on the other side of the rectifier is ~35Volts. Actually lower.
What do you make of that? Half wave rectifier?
I agree with you on your other points.
HRMM
For instance, is that 38VAC you reference a measured voltage and did you measure it with an RMS-capable DMM? Only the better, more expensive DMM's can accurately measure VAC RMS voltage. Cheaper meters may be measuring Vp-p, which will be much higher.
