Tilpo
- Mar 2, 2011
My thoughts exactly.
I worry not though. This guy has done far more dangerous things with electricity and lived to tell the tale.
I just got here and am happy to see you being more careful. Maybe you could build a drain into the headpiece between your ear and the plasma. Grounded open screen etc. Thats a scary ozone generating device your making.
4Very short exposure could cause death or major residual injury (e.g., hydrogen cyanide, phosphine, carbon monoxide, sarin)
4Readily capable of detonation or explosive decomposition at normal temperatures and pressures (e.g., nitroglycerine, Trinitrotoluene)
yeah I would be endeavoring to find out how much spontaneously explosive sarin equivalent gas, my experimental lethally high voltage headphones were likely to produce before putting them on as well …
If you pumped argon very slowly through the headphones, they'd make almost no ozone. Of course, you'd need cylinders of gas to listen to them, but a large cylinder could last I would make an uncalculated guess of many many hundreds of hours of listening if it were setup right. Gasses like argon are readily available due to their use in welding.
But the headphones are completely open, wouldn't that fill the entire room with argon??
While O3 isn't explosive, it is still a very strong oxidizing agent. That means flammable substances MAY spontaneously combust in its presence and flames will burn much stronger.
So until I get them tested, I'll be using them under a fume hood or something similar (i.e. stove exhaust hood).
yes, some would leak out, but even at a very low flow-rate a very large fraction of the gas inside the headphones would stay argon and even the slightest air flow in the room would make it mix right in and leave plenty of oxygen to breathe. Both of these issues are quite similar in welding, and neither are an issue.
Of course, it is somewhat impractical to have large gas cylinders, but for a demonstration piece it could be done. If you don't plan on listening for long and are mainly doing it to do it and have a demo piece, though, the ozone won't really be an issue. I've breathed plenty of ozone briefly while working with high voltage. While it's not really good, brief exposures aren't going to kill you or anything.
i'm well aware its only very unstable and could potentially explode in reaction to the environment, when, for example there is air being broken apart in the presence of >1kV. did you really just pick holes in a completely fantastic piece of piss taking?
Sorry, but I'm not sure what exactly do you mean by that....
