scootermafia
MOT: Double Helix Cables
- Nov 24, 2008
Knew that one would rile you all up!
There are some cheap balanced items that aren't worth owning. I don't think any $1200 single ended solid state amps can compete with the balanced output of the Phoenix. I think the gains in power and channel separation you get from balanced amps make it such that single ended (besides some of the nicer tube designs, WA5 etc) should be limited to low budget products, stuff <$1000. Apart from just blatantly bad designs, in general using separate copies of a certain configuration for left and right, keeping the two independent, helps keep left/right separate.
If you have a chain of expensive, well designed items of roughly the same budget, I think the setup that is balanced will have a competitive advantage. I'm not saying that all badly designed balanced items can instantly defeat a really nice piece of SE gear. But isn't most gear that is dual mono inside (or gear with dual power supplies) going to be inherently better at least in terms of channel separation than gear that mixes things up ? Balanced designs lend an advantage.
After hearing the gains I got from switching from Havana and M3 to DAC8/Ref1 and Phoenix, I have respect for the advantages of balanced designs.
