Shub-Niggurath
- Aug 13, 2004
I've installed the plugin, and when I try to play any file, it plays the first split second and then stops. The app doesn't crash or anything, it just stops playing after <1 second. I can always double-click on the track again with the same result.
I just uninstalled Winamp, made sure its folder no longer existed, downloaded it from winamp.com, reinstalled it, then reinstalled this Maiko plugin, same result.
Note I typically remove a bunch of useless things from my Winamp install, but I shouldn't think it would cause a problem. Am I doing something wrong? I have to say that first split second of playback sounds really nice compared to the default DirectSound plugin!
Edit: I tried enabling Maiko's exclusive mode. Result: instead of playing for <1 second and stopping, it plays the same <1 second of the file in a loop.
I also checked the option in the settings that tell Maiko to release the device from exclusive mode and reclaim it when needed, and it worked. Then I set Winamp back to using DirectSound just to compare the sound, then set it back to Maiko (same settings -- exclusive + release when not needed) and it's broken again
