I pasted the DLL into my winamp plugins folder but its not showing up in output? I only see disk writer/direct sound output/waveout output. I enabled "Allow 24bit" too in playback. Am I missing something?
EDIT: Looks like this is for Windows7/Vista, not XP. Nevermind :/
Edit: Fixed it. had to change my audio settings to 24/96 in windows.....
but now I have a new problem. the songs now skip for about .1 seconds in random places throughout the entire song. All my songs are doing this. Any fix for this?
Edit: Fixed again. Had to turn my power options into "High Performance"
Hopefully if anyone has any problems with the above they'll read this.
It doesn't play my song after I do this.
They play for about half a second and stop.
Any help?
Thank you BleaK for posting this!
I've been thinking about using foobar just for Bit-Perfect playback, but was holding off on it because it doesn't sync well with an Android phone.
Winamp has everything I want from it, and it syncs perfectly with my Android.
I do have a question though. What would be the difference between Maiko plugin and Asio4All when used in Winamp?
I would say there is no difference in the Maiko plugin and asio4all sound wise. However the Maiko have alot more options at hand. I don't use many of the extra things that the Maiko plugin offer (unless the exclusive mode when doing serious listening), but if I wanted to I could delve into alot more. It also handles multiple channels, so if you want to play 5.1-songs Maiko let you do this as well.
